Old 05-24-2020, 07:58 AM   #1
oldford2
oldford2's Avatar
Default condenser re-locating to coil
I received a PM from Moe up in Canada on details for moving the condenser up from the distributor to the coil. I tried to reply to his PM but there is no icon for attaching pictures in a pm (?) so I am posting it here in the forum for all. Make a piece of steel about 1/2 by 3 and drill a hole at the bottom and one at the top. Remove the condenser from down at the distributer. Mount the strip to the bolt that holds the coil. Then connect the condenser to the coil terminal that goes down to the distributer.
oldford2 is offline   Reply With Quote
Old 05-24-2020, 01:13 PM   #2
coolcoupe
coolcoupe's Avatar
Default Re: condenser re-locating to coil
John,thanks again, Moe
coolcoupe is offline   Reply With Quote
Old 05-25-2020, 01:28 PM   #3
GB SISSON
GB SISSON's Avatar
I like that location. I wish I could mount the whole distributor up there!
Old 05-25-2020, 06:42 PM   #4
JayChicago
JayChicago's Avatar
Yea, I want to do that too! Went to remove my condenser today, and what a pain to get to it! (on a 37, on an aftermarket Mallory crab, with an electric fan in the way)
Anyone know of a downside to mounting the condenser off the remote coil like that?
Old 05-25-2020, 07:13 PM   #5
Jack E/NJ
Jack E/NJ's Avatar
Sorry. I think there's probably only an upside. 8^) Jack E/NJ
Old 05-25-2020, 07:14 PM   #6
oldford2
oldford2's Avatar
This was brought up some years ago by 42 guy who raced flatheads. Some electric guys thought that because of the distance there was some drop in mili??? Bottom line was that for drivers this was a good re-location. The first time we have what we think is sudden ignition problem we take the first and easiest try which is to replace the condenser. Many times that is the answer. On the side of the road at night this is no fun.
So my opinion is there is no downside. My 46 has been like that for 10 years and the one time it started bucking and running poorly a new condenser took care of it. Easy change.
John
Old 05-25-2020, 07:47 PM   #7
tubman
tubman's Avatar
A longer lead does add to the capacitance. If you look at a high-end condenser tester, it will have special short leads to be used when testing condensers for exactly this reason. Most Mallory distributors have a brass strap for connecting the condensers. Even with all of that, it probably doesn't make enough difference to be concerned about.
Given all of that, if you are making a longer condenser lead, use at least 12 gauge wire (10 is even better but sometimes a little unwieldly).
Old 05-26-2020, 04:55 PM   #8
42guy
42guy's Avatar
You can use a condenser from early 80's Mopar. when I started this, I was in touch Std. Blue Streak and they recommended AL111X. I have had the same condenser for 15 yrs, When I purchased them, they were still made in the USA.
42guy is offline   Reply With Quote
Old 05-26-2020, 06:22 PM   #9
coolcoupe
coolcoupe's Avatar
That condenser can be used in a 47 Ford V8 and 6 volt car?
Old 05-27-2020, 02:27 AM   #10
dumb person
dumb person's Avatar
All ignition coils spike up to near 80+ volts on the primary side so it's likely they would work fine.
<Link> This is how we roll<Link>
"I'm Convinced that no one really reads posts anymore; they just fabricate what they think the post says then ramble on about red herrings."--Bob
Outcasts rules of old cars
#1 Fun is imperative, mainstream is overrated
#2 If they think it is impossible, prove them wrong
#3 If the science says it impossible you are not being creative enough.
#4 No shame in recreating something you never had
#5 If it were not for the law & physics you would be unstoppable
dumb person is offline   Reply With Quote
Old 05-27-2020, 08:52 AM   #11
G.M.
Condensers work in 6 or 12 volts systems. Th voltage to the coil
wants to be 4.0 volts. Higher burns points and lower is hard to
start. G.M.
www.fordcollector.com
Old 05-27-2020, 08:28 PM   #12
JayChicago
JayChicago's Avatar
I think it should be noted for new guys that is with engine running or cranking, points opening and closing. For those working in the garage with engine stopped, about 3 volts at the coil is normal. Later when engine is turning, points open 20% of the time, no current flow and therefore no voltage drop thru the resistor 20% of the time, averaged voltage will then jump up to 3.5 to 4 volts.
Old 05-27-2020, 09:04 PM   #13
Jack E/NJ
Jack E/NJ's Avatar
With a 30* dwell closed, I think points are open closer to 67% of the time. 8^) Jack E/NJ
