AOD to flathead
I know this message board is not for “hot rods” or customs, this AOD is just about the only thing I’m upgrading on this car. Everything else will be pretty stock.
Anyway, my question is the kit from speedway motors came with a bunch of nuts, bolts and washers. I have four star washers. Do they go on the flex plate to crank shaft bolts or torqu converter to flexplate nuts?
And then which ever one they go on do the other ones require some sort of lock washer?
They only gave me four star washers so those go on one or the other. They gave me 6 split washers and 6 nuts which I’m fairly confident those go to the studs that attach to the trans.
I appreciate all you guys’ help!
