Old 03-31-2020, 04:40 PM   #1
jack wingard
Default Horn Wires Polarity
Horn wires were soldered inside the conduit. When I disconnected I forgot to mark what was which and the wires are different colors out the horn that don't match the supply. Does it matter how they are connected?
jack wingard is offline   Reply With Quote
Old 03-31-2020, 04:49 PM   #2
FordTudor1931
FordTudor1931's Avatar
Default Re: Horn Wires Polarity
No, it makes no difference.
FordTudor1931 is offline   Reply With Quote
Old 03-31-2020, 04:49 PM   #3
dennis lumbert
dennis lumbert's Avatar
No polarity does not matter on the horn.
dennis lumbert is offline   Reply With Quote
Old 03-31-2020, 05:12 PM   #4
jack wingard
thanks
Old 03-31-2020, 05:24 PM   #5
rotorwrench
rotorwrench's Avatar
If it is slow to react or sounds sluggish after connecting it up, reverse the connections and see if there is improvement to the tone. It certainly won't hurt it to connect it either way. Most folks don't sound the horn very long. On a motor driven horn, the motor will change its direction of rotation when the polarity is switched. When they get used to going one direction and wear in that way, it can sometimes change the tone when it goes the other way.
Old 03-31-2020, 08:16 PM   #6
CT Jack
CT Jack's Avatar
The horn uses a DC motor which can run or rotate either CW or CCW depending on the connections (+ or -). The horn will work either way.
CT Jack is offline   Reply With Quote
Old 04-01-2020, 05:31 AM   #7
Werner
Werner's Avatar
Guten Morgen,
the motor is a series connection type. The collector and field winding are connected in series. Therefore, as already written at the beginning of these articles, the direction of rotation is always the same, no matter where + or - are connected. (It's the same with the starter motor.)
Since the "Waltons" is used only rarely and for a short time, I occasionally let it run for several minutes in the distance outside of people.
In addition, I switched a powerful current relay (25 A) with thick cables in between the battery and horn connector and one on the ground area.
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 04-01-2020, 08:56 AM   #8
rotorwrench
If it's an original motor. A lot of them aren't now days.
Old 04-01-2020, 09:44 AM   #9
burner31
burner31's Avatar
Positive ground = A-hooga sound
Negative ground = A-hooga sound
Keith
Shawnee OK
'31 SW 160-B
