Old 02-24-2020, 07:38 PM   #1
Tod
Default First (second really) 5 main aluminum block.
OK, here we go with the first aluminum 5 main block just out of the sand. After talking to the foundry, it sounds like I need to provide for chilling a few spots, but for the first attempt in a new molding and pouring method, I think it looks pretty good. Can only get better from here on.
Tod
Tod is offline   Reply With Quote
Old 02-24-2020, 08:07 PM   #2
rotorwrench
rotorwrench's Avatar
Default Re: First (second really) 5 main aluminum block.
Welcome to the 21st Century 200 CID Ford. What a jewel. That's going to be the cat's meow for the hot rod 4-banger guys.
Old 02-25-2020, 01:15 AM   #3
The Master Cylinder
The Master Cylinder's Avatar
Very Kool, Rod.
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
Old 02-25-2020, 07:06 AM   #4
Tod
Aluminum and 5 main blocks are just an aside for me (although I have dozens of people wanting these already). My main focus will be 3 main A and B journal blocks that people can use parts they already have to build. I did this just for more 5 main fun and to test my new aluminum foundry out. I think they did well. I assembled the mold Saturday morning, they poured it shortly thereafter, and Monday they had that to show me.
Tod
Old 02-25-2020, 08:56 AM   #5
motordr
Great stuff!
motordr is offline   Reply With Quote
Old 02-25-2020, 11:05 AM   #6
Jw
have you considered moving the water port back by cylinder number 4 to increase cooling
Jw is offline   Reply With Quote
Old 02-25-2020, 11:10 AM   #7
Seth Swoboda
Seth Swoboda's Avatar
That's pretty amazing. I can't imagine the cost it takes to get this endevour started let alone to a final product that is marketable.
Have you considered an aluminum flathead V8 block?
Old 02-25-2020, 01:35 PM   #8
Tod
Cost is negligible given that I do pretty much everything myself. Don't be impressed. It is more time consuming than difficult. I've made castings that make engine blocks look like child's play. Finding time is my largest problem.
I have an 8BA model almost finished. Probably stick with iron on that, though.
Tod
Old 02-25-2020, 01:36 PM   #9
Tod
No.
Old 02-25-2020, 01:59 PM   #10
rotorwrench
Ford delt with cooling in the last of the flatheads by opening up the cylinder head in the back and forcing more coolant to flow back there. I don't know if I'd worry about it much. The 24 stud V8 engines all had the coolant pushed in from the front and they seemed to survive it OK. When they opened up the 8BA block in the back it was due to the larger heavier vehicles they were being used in and they did OK as well as long as all the core wire and casting sand was removed.
With the starter motor back there, it might make more problems. I'd say keep it simple.
Old 02-27-2020, 04:59 PM   #11
Tod
I stopped by my iron foundry today while I was running some errands to look over the 3 main block they recently poured. They have not run it totally through the grinding room yet but, WOW, does it look good for an unfinished casting! I can't wait to get at machining it and getting these things into the hands of waiting customers and builders.
Tod
Old 02-27-2020, 05:10 PM   #12
Lawrie
Lawrie's Avatar
Good work .
Cant wait to see the 3 main iron ones.
Lawrie
Old 02-27-2020, 05:22 PM   #13
Tod
Originally Posted by Lawrie View Post
Good work .
Lawrie
I knew you would like that. You will love what you see. I will email you pics first.
Tod
Old 02-27-2020, 05:41 PM   #14
Jw
very impressive!
Old 02-27-2020, 05:48 PM   #15
Jw
question. is the blocked sleeved or like the Vega blocks?
Old 02-27-2020, 06:35 PM   #16
Tod
Aluminum use ductile sleeves. The iron blocks obviously do not use sleeves, not for another 50-75 years, anyway
Tod
Old 02-27-2020, 07:12 PM   #17
DBrer
Great, I'm sure your efforts will pay off.
DBrer is offline   Reply With Quote
Old 03-02-2020, 12:55 PM   #18
Tod
A picture of the 3 main A block we just cast before getting rid of the parting line flashing and gating residue. Can't wait to machine this one. Yes, that is a B head sitting next to it. Also a couple of iron Winfield heads on that skid.
We will grind off flashing etc... and then final shot blast. Then I get it here to the shop and machine it.
Tod
Old 03-05-2020, 04:30 PM   #19
Tod
Just got back from picking up some castings at the iron foundry. B heads, Winfield heads, and a 3 main A block.
Tod
Old 03-05-2020, 05:41 PM   #20
Russ/40
Russ/40's Avatar
Tod, I see the head gasket in photo 4. Are you an advocate of that type gasket?
