Old 07-31-2019, 04:25 PM   #1
artron9
Default 52 vic temp gauge markings
I would like to know the temp readings for each of the markings on the temp gauge of my 52 Vic. In other words, the markings between C and H. Thanks,as always, for your input!
artron9 is offline   Reply With Quote
Old 07-31-2019, 04:44 PM   #2
51 MERC-CT
51 MERC-CT's Avatar
Default Re: 52 vic temp gauge markings
Cold, medium cold, medium, medium hot, hot.
Old 07-31-2019, 04:57 PM   #3
34PKUP
34PKUP's Avatar
Funny.
Never heard of any temperature being assigned to any makings on the gage.
If it imperative that you know the temperature at those points then hook up a mechanical gage and use it to record and transfer those readings at each mark to the original gage.
34PKUP is offline   Reply With Quote
Old 07-31-2019, 05:47 PM   #4
JSeery
JSeery's Avatar
Or use an IR Heat Gun and check at the neck on the heads. Don't believe the marks have any numeric value assigned to them.
Old 07-31-2019, 06:42 PM   #5
artron9
Thank you guys! That's all I need to know! Just thought there should be a numerical value attached to those primitive markings.
