Old 12-12-2018, 08:18 PM   #1
Michael Allen
Smile 54 Victoria ride height
Hi to all and hoping some of you owners of 52, 53 or 54 Victoria's can provide some measurements for factory type ride height. The measurements I need would be taken at the front and rear frame ends; bottom of the frame to the ground. Thanks in advance. Merry Christmas to all.
Michael Allen is offline   Reply With Quote
Old 12-13-2018, 09:37 AM   #2
KULTULZ
KULTULZ's Avatar
Post Re: 54 Victoria ride height
TRIM HEIGHT is what you are after, measuring OEM specs for proper vehicle height. After all of these years, it would be hard to find two that sit alike (IMO).
Those specs must be in a separate manual as I do not see them in the SM. Usually they were found in frame machine info manuals or aftermarket alignment machine manuals (if not using ROTUNDA).
Here is an explanation- https://www.autozone.com/repairguide...00c152800a841f
"Last Sunday, I caught him makin' eyes at Idell Bushey durin' preachin'. And I know what they do up there in the hills when they say they're possum huntin'. They're just sittin' around the campfire, drinkin' hard cider, hittin' each other on the shoulder and hollerin' 'flinch!'."
― Charlene Darling (Daughter of Briscoe Darling)
KULTULZ is offline   Reply With Quote
Old 12-13-2018, 11:56 AM   #3
Michael Allen
Default Re: 54 Victoria ride height
Thanks for your reply. My thought was that an owner of an "original" might measure their Vicky which would give me a "close approximate" height to work from. I have modified my front suspension as to how the upper control arms are mounted. This was necessary for engine clearance. After the initial mods I found that I needed to add more caster because of adding a rear steer rack and pinion. For proper placement of new control arm mounts (to provide 4 degrees positive caster) the frame should be set at the desired ride height when the mounts are fabricated. The original specs for caster is 1 degree positive. It would be difficult and/or unsightly to add the required stack of shims to achieve 4 degrees positive caster. Thanks again.
Old 12-13-2018, 01:34 PM   #4
KULTULZ
KULTULZ's Avatar
Oh, in your case you might want to consider a completely adjustable control arm. Then you can adjust from any trim you decide on (perf - looks).
Ain't nothing worse that a shim pack falling out while being chased by revenooers ...
Old 12-13-2018, 06:46 PM   #5
JeffB2
JeffB2's Avatar
You might want to ask here: https://www.facebook.com/groups/54FordClub/ It is an all 1954 Ford forum.
JeffB2 is offline   Reply With Quote
Old 12-13-2018, 08:24 PM   #6
Michael Allen
Thanks guys. Its a long story of making room to fit a DOHC 4.6 Lincoln between the upper control arm brackets. Hope someone out there is willing to measure their Vicky and provide some measurements. Thanks again.
Old 12-13-2018, 09:30 PM   #7
miker98038
miker98038's Avatar
That sounds like a fun “Ford in a Ford” project. Having been there on my 55 bird, you’re on the right track for the increased caster.
miker98038 is offline   Reply With Quote
Old 12-14-2018, 10:41 PM   #8
Michael Allen
As to the "Shelby" relocation of the upper arm, at this point no. My top heavy Vicky would not benefit as much as your much lower T-Bird. I spoke with Brent Vandervort of Fatman Fabrications concerning altering the placement and his advice was to leave that as original but add the additional caster. Another option was to include an "anti-dive" angle along with the caster. Maybe, maybe not. By the way; anyone wanting to learn much about suspension geometry I would recommend Fatman's Hot Rod Suspension book. Still looking for a kind and generous Vicky owner willing to provide some height measurements....PLEASE.
Old 12-16-2018, 06:40 PM   #9
Michael Allen
Found a 54 nearby. Measurements are approximately 12 inches for the front and 15 inches for the rear. Now I can begin the modifications.
Old 12-17-2018, 12:53 AM   #10
slumlord44
On my '57 T Bird the ride height specifications are measured from the floor to the center of the headlight on the front and the center of the tailight on the rear. I think I the measurements from the factory shop manual.
slumlord44 is offline   Reply With Quote
