08-13-2014, 03:58 PM | #1 |
Looking for Hyatt Bearing Cross Reference
Does anyone have an OLD Hyatt Bearing cross reference book, I am trying to figure out some AA Bearings that are "No Longer Available from Suppliers"
Google and the online bearing suppliers do not seem to be of much help. Thank you, Don Jr [email protected] |
08-13-2014, 05:06 PM | #2 |
Re: Looking for Hyatt Bearing Cross Reference
How about some numbers??
Bob |
08-13-2014, 07:24 PM | #3 |
Cutter Sales has bearings and seals by number, application, or by giving the dimensions. 763-425-8696
08-14-2014, 01:58 PM | #4 |
Tom, Cutter can only go back to 1962.
Bob C, Hyatt 00537, looking for the original ford part number. |
08-14-2014, 03:02 PM | #5 |
I have a reprint of a cross referenced book at home that crosses numbers from all sorts of things for cars in the early 30's. I think it is a Chilton's. When I get home I will look to see what I have for bearing #'s. I might have something that will get you to another number that you can use.
Mikw
08-14-2014, 03:04 PM | #6 |
the Studebaker number is 630170. BB-1225 will work but you need two for each hub, the Bower number is J92-3657. Bob |
08-14-2014, 03:12 PM | #7 |
I have about 100 NOS Hyatt bearings and several hundred others to figure out. If you find a cross reference book I may want to rent it from you. Rod
08-14-2014, 03:59 PM | #8 |
Have you tried cross over by the measurements ?
08-17-2014, 07:23 PM | #9 |
Sorry All I have is numbers for the cars.
Mike
08-17-2014, 08:31 PM | #10 |
Thanks guys, Bob C. Saved the day! Thanks again.
08-04-2018, 11:19 AM | #11 |
i am looking for a hyatt 1 inch ID, 1.5 OD and just a hair over 1.5 inch tall, maybe 1 32'' over. thank you, [email protected]
08-04-2018, 03:15 PM | #12 |
Here's a couple. ID 1.000 OD 1.500 W 1.4531 Bower J32-1648,. Hyatt, SKF or
New Departure 94524. ID 1.000 OD 1.500 W 1.5781 NAPA or Bower J32-1652, Ford GTB-7287, Hyatt or SKF 94526. The number they show for Ford seems wrong as 7200 numbers are for the gear shift. Bob |
