Old 05-18-2018, 01:13 AM   #1
Gary Tosel
Gary Tosel's Avatar
Default 36 Ford Radio On/Off Switch
Has anyone found a source for the 36 Ford Philco radio head on/off switch?
I have three radio heads that click like on/off but do not work. I have taken them apart and find it is the most complicated switch to perform on/off operation.
The weak link is the fiber switch lever that wears out on the pivot end and will not allow the rotary switch to make contact. I am in process of replacing that part, but it is really difficult to complete.
Let us know if there are new or replacement switches available.
Thanks
Gary Tosel is offline   Reply With Quote
Old 05-18-2018, 01:49 AM   #2
petehoovie
petehoovie's Avatar
Default Re: 36 Ford Radio On/Off Switch
I always thought the on/off switch was located inside the radio chassis and not in the radio-head. This on/off switch in the chassis being actuated by the cable from the radio-head left hand knob. Can you post a picture of the radio-head you have?
See > https://www.ebay.com/itm/BEAUTIFUL-1...AAAOSwxupa~c4s
Old 05-18-2018, 04:28 AM   #3
Don Rogers
Don Rogers's Avatar
Pete, When Ford went from the larger Philco FT-6 radio chassis to the smaller FT-9 chassis in early 1936, the on-off switch was moved from the chassis to the radio head. See photo of 1936 radio head with integral switch.
Don Rogers is offline   Reply With Quote
Old 05-18-2018, 12:42 PM   #4
petehoovie
petehoovie's Avatar
There's a seller on eBay who refurbishes old car radios > partsgeneral1200
You might want to contact this guy for the part you need....
Old 05-18-2018, 01:12 PM   #5
keith oh
keith oh's Avatar
The only cure I have found for the 36 switches is to eliminate the faulty head switch with a shunt and put a little hide able in line switch in the power line between ignition switch and head. I did see one a guy had put a 1935 switch in the 36 box, he must have changed the cable also, I never had a chance to ask, the "dooer" was a couple owners back.
keith oh is offline   Reply With Quote
