I have a 2 carb Offenhauser intake manifold with twin 97s on it but having difficulty finding the correct throttle and choke linkage for this unit .Where do I find the rods and connectors ?
I like 3/16 dia steel round stock, HEIM ends & throttle arms from Speedway. Check
page 280 in the Speedway catalog.......items 5601007 thru 6181 and HEIM ends 175-0100 & 175-0200 page 10 Charlie ny |
I presume its for your '32,right? For the choke,depending on the spread of your carbs you might not be able to use the '32 choke rod as it was.You might have to shorten or lengthen it. If you prefer to run a cable choke,I have this that can work but you have to change out the kicker linkage. Last edited by deuce lover; 05-31-2021 at 08:34 AM. |
