For years I have been accumulating parts to change my stock 49 Mercury to overdrive.
The completed unit is assembled but with cover off it turns freely in neutral but will only shift into second. When shifting to high, low or reverse it will only turn a few degrees. The 28 tooth cluster appears New and has the right tooth count. I have have checked the tooth count on all gears. I disassembled and reassembled to check for errors and found none. The overdrive turns freely and will free wheel with lever forward. After I put it together again today it did the same thing. I'm no mechanic but I've done this a dozen times over 60 years. Had the shop manual in front of me. I'm stumped. Anyone have any ideas? |
I am by no means an expert, but maybe the reverse lock out shift rail is not working correctly. rotorwrench here on the barn is very familiar with the o/d trans. maybe he can give you some ideas
“The overdrive turns freely and will free wheel with lever forward. “
If the lever you’re referring to is the one that locks up the O/D and its all the way forward the O/D function should be locked out and the transmission shouldn’t be free wheeling. When you turn the input shaft with second gear engaged does the output shaft turn? I doubt that the shift rail is the source of this problem, but it sounds like there is an issue with how its interacting (or not) with the O/D which should be checked out. |
Is the solenoid attached? If the balk ring is engaged with the od lever locked out it won't work.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound |
The overdrive control should be in the locked out position to test the transmission shift function. The input needs a bit of rotation to get tooth alignment for the gears & blockers to mesh. If the thing won't shift from 2nd to high then there may be a problem with the synchronizer. The reverse gear selection pushes a lever that in turn pushes the lock out rail inside. If the OD is in lock out then reverse should go in. As Frank mentioned, the overdrive will not lock out if the actuator pawl is fully engaged with the balk ring. It has to be in the fully disengaged position. If not, the shift rail can't move to block the pawl.
Wow! That is a real pretty transmission!
To clarify: I am testing this unit with the overdrive lever in the lockout position, no solenoid attached, shifting cover off, and out of car. I made a tool to pull the balk ring out and I believe it is in position where I could attach the solenoid The final drive does not freewheel and the unit works fine in second and neutral. I am not in 2 gears at once To test the overdrive for freewheeling I engaged the lockout lever and the output shift will freewheel. The baffling thing is, if it turns in neutral and second, why doesn't high work? It's not stuck as the main drive will turn, but only a few degrees. I'm going to try another synchronizer but even if it fixes high that doesn't explain low and reverse. The cluster is 28-24-16-14 with a 16 tooth main and 29 tooth slider. I hope I remember this right. Notes are at the shop. It all turns smooth in neutral. And if the synchro change doesn't work I have a conventional tail housing I can install to isolate a possible overdrive problem. Thank you all for your ideas. |
