Old 10-06-2010, 01:01 PM   #1
Art Bjornestad
Art Bjornestad's Avatar
Default overdrive transmissions
I am trying to find suppliers of kits to install a Ford 4 speed OD tranny in my A. Dave@modelaonly is not returning emails or answering calls. Has anyone used another supplier and how can I contact them? Thanks
Art Bjornestad is offline   Reply With Quote
Old 10-06-2010, 01:52 PM   #2
Logan
Logan's Avatar
Default Re: overdrive transmissions
Gary Bernard in ft worth. Weve put over 20k miles on ours and I LOVE it. I know George Tynan has put around 50k on both of his. Gary has been making them for around 20 years, and have never heard of any problems. Private message me for contact info. His kits i beleive are around $2500
Cowtown A's
Logan is offline   Reply With Quote
Old 10-06-2010, 03:59 PM   #3
MikeK
MikeK's Avatar
Perhaps Dave is in Hershey this week enjoying a respite from email & phone. I remember when snail mail (USPS 1st class) was considered speedy, and long distance phone calls required an operator to call back when a line was available. Try him in a week. Surely you can wait? You can see his stuff on his website.
MikeK is offline   Reply With Quote
Old 10-07-2010, 07:49 AM   #4
john in illinois
john in illinois's Avatar
I have Dave's kit . You do not have to cut up your frame crossmember or your brake cross shaft ,as with other kits. It is a drop in kit.Works great.
john in illinois is offline   Reply With Quote
Old 10-07-2010, 08:19 AM   #5
Pa Joe
Pa Joe's Avatar
What is Daves web address. thanks Joe
Pa Joe is offline   Reply With Quote
Old 10-07-2010, 11:06 AM   #6
1928Pickuppain
1928Pickuppain's Avatar
How mush more speed do you get from the fourth gear
1928Pickuppain is offline   Reply With Quote
Old 10-07-2010, 11:44 AM   #7
AL in NY
AL in NY's Avatar
Here is an email from Ken Parker who posts on Fordbarn concerning his F150 kit:
From [email protected] ([email protected])
Sent Sunday, June 17, 2007 9:25 pm
To [email protected]
Cc
Bcc
Subject F150 OD transmission
Saw your post on Fordbarn. There are two shops in Texas that build the units you speak of. Gary Bernard and me. Both built from F100 or F150 transmissions but how they are cuopled to the model A is slightly different. My units uses a AA bell housing and requires no cutting on the center cross member of modifications to the brake cross shft. It is complete with AA bell housing, Throwout bearing and hub, new Clutch disc, transmission - rebuilt, Shortened radias rods, shortened torque tube, shortened drive shaft, Clutch and brake pedal bracket, 30-31 style emergency brake bracket, Shift lever adapted to look like model A. All nuts and bolts for installation included. Complete package $2500. I have further info if you want it and pictures.
I am in Van, Texas - 80 miles east of Dallas. Ken Parker 903- 963-1650
Note the date 6/2007, the price may be slightly higher now. I installed one myself and have instructions if you are a real good mechanic and have access to a lathe and milling machine. And Art, I sent you my instructions which also list the three fellows (Gary, Ken and Dave) who make the F150 kits and their contact information.
AL in NY
AL in NY is offline   Reply With Quote
Old 10-07-2010, 11:55 AM   #8
Jim Brierley
What are the gear ratios of the 4-speed? The only one I have ever ridden in had a HUGE RPM drop between 2nd and 3rd gears, other than that it seemed to work nicely. I personally would go for the Mitchell.
Old 10-07-2010, 07:15 PM   #9
Jim Parker Toronto
Jim Parker Toronto's Avatar
Here's some info I got for mine, I think it was from modeladave's (not sure)
Overdrive Transmission:
The Overdrive transmission 1928-1931, 1935-1939 is a unique, fully-synchronized, transmissions for the Model "A" and early V8. It has the overdrive built inside the case. There are no extra leavers, cables, or electric switches involved.
The drop in conversion kit that I manufacture has all parts necessary for a drop in installation. No special tools are required.
There are 4 different ratios:
.......................1..... 2 ...... 3 .......4
Gear Ratios...1st - 3.01.... 3.25 .... 3.25 .....3.01
.....................2nd - 1.78 ....1.92 ....1.92 ... 1.78
......................3rd - 1.00 ....1.00.... 1.00 ....1.00
....................O.D. - 0.72 ....0.71 ....0.78 ....0.79
....................Rev - 3.01 ..... 3.25 ....3.25 ....3.01
1984-1987 Ford light duty top shifter. It is a three speed with the fourth being overdrive and all gears are synchro in forward direction. Believe it is Tremac transmission. I also believe that you want the one with the long tailshaft. Also believe that there were a couple or three ratios of that transmission offered. You should be looking for a TOD (top shifter, overdrive), T170FT (code-RTS).
Last edited by Jim Parker Toronto; 10-07-2010 at 07:30 PM. Reason: alignment of numbers, Won"t stay where I put them, done it twice, sorry
Jim Parker Toronto is offline   Reply With Quote
Old 10-07-2010, 09:23 PM   #10
38 coupe
38 coupe's Avatar
Can the earlier top loader overdrive transmission be converted for this too? I'm talking about the cast iron case Ford top loader looking transmission (that the muscle car guys like) only with the 3-4 shift lever flipped and overdrive where 3rd used to be. I know you can put a Jeep top on a Ford top loader to get a top shifter.
Old 10-07-2010, 10:09 PM   #11
Jim Parker Toronto
"Can the earlier top loader overdrive transmission be converted for this too?" ......of course it can, all it takes is time, some engineering, some machine shop work, a little bit of money, and the desire to do it! Go for it!
Old 10-08-2010, 11:15 AM   #12
Jim Brierley
Thanks for the ratio chart Jim, I've been running a Columbia under my widebed for some 40 years, works great and I like the ratios.
Old 10-08-2010, 08:43 PM   #13
Jim Parker Toronto
Jim, I am putting that F150 transmission behind a B motor that Ted Koudy just put together for me. I can't wait till next spring!
Old 11-09-2010, 04:14 PM   #14
CarlG
CarlG's Avatar
I have also been trying to contact Dave without success. I have several of his other products installed on my 31 PU, and wanted to do the tranny this winter, but he has yet to respond. I've been trying for about a month.
Old 11-09-2010, 04:24 PM   #15
JoeWay
JoeWay's Avatar
I heard Dave had been on an extended vacation and just returned in the last few days.
Joe
1929 Tudor
since 1962
Feather River A's
JoeWay is offline   Reply With Quote
Old 11-09-2010, 08:59 PM   #16
southfork
southfork's Avatar
Can someone give specifics on exactly what the referenced Ford 150 overdrive transmission is, please? Is it hard to find, or not so hard? In what price range are they found at wrecking yards?
southfork is offline   Reply With Quote
Old 11-09-2010, 09:09 PM   #17
Jim Parker Toronto
southfork, it is a 1984-87 Ford 1/2 ton six cylinder or small V8, made by Tremac and has a serial # that starts with RTS. They are not real rare, but will be hard to find, and should be around $500.
Old 11-09-2010, 10:46 PM   #18
AL in NY
AL in NY's Avatar
Search the "Barn" for "F150" and you'll find all the information you will need to find the correct transmission.
AL in NY
Old 11-15-2010, 08:52 PM   #19
CarlG
CarlG's Avatar
Dave is back from his extended time out of town. I heard from him today!
Old 10-18-2011, 11:08 PM   #20
4bangerrodder
Has anyone tackled the exteme drop in RPM from the 2nd to 3rd shift. In Colorado, the forward motion really drops on it's face when you shift, 1st and 2nd is fine, after a good run 3rd is ok, but it takles a while to get the rpm back after that shift from 2nd to 3rd. And 4:11's don't help it even with a good inserted engine!!
4bangerrodder is offline   Reply With Quote
