Old 08-02-2017, 05:28 PM   #1
john charlton
john charlton's Avatar
Default 28/29 Briggs blind back top question.
I have seen two different styles of top . My 29 fordor the top welting which runs across the back top above the rear window is in one piece . This terminates each side several inches down the side curve . It looks the same as the archive pics . At a car show in Phoenix I saw a very original looking blind back fordor where the welting started at the back of the rain gutter ,swept down past the rear side window then abruptly up and across the back to the other side,seemed that the welting was in three pieces . This top seemed to be on an unrestored car . Were some cars built this way ???. There is one on You Tube a black car with the same top .Just wondering .
John in heavy rain low pressure Suffolk County England .
Old 08-07-2017, 09:49 AM   #2
Russ
Russ's Avatar
Default Re: 28/29 Briggs blind back top question.
John, it sounds like you may be describing the difference between a 60-C Fordor and a 170-A Fordor, both of which were made in 1929. It's a bit difficult to visualize what you are describing - can you send a couple pictures?
Russ is offline   Reply With Quote
Old 08-07-2017, 10:14 AM   #3
asapguy
asapguy's Avatar
Russ this is the two types of seams John is referring to. I have seen several 60 A & B fordors done both ways. I believe the left picture is the correct way.
asapguy is offline   Reply With Quote
Old 08-07-2017, 12:28 PM   #4
john charlton
Thats it ,thank you asapguy !!! I have seen several cars with the 3 piece welting,one at a car show in Phoenix that looked very very original . I should have sought out the owner and asked him . Maybe the Town Sedan group might know. I had thought the welting was in 3 pieces but your pic shows maybe one long piece.
John in cloudy evening Suffolk County England .
Old 08-07-2017, 01:23 PM   #5
Russ
Russ's Avatar
Thanks for the photo-clarification - not what I was thinking.
Old 08-07-2017, 08:49 PM   #6
jrelliott
jrelliott's Avatar
The kit I got from LeBonney has the style of top in the left that asapguy posted.. One fo the books that I have "The cars that Henry Ford built" show the style of the one on the left also.
Old 08-08-2017, 03:40 AM   #7
juke joint johnny
juke joint johnny's Avatar
In the second photo above they have followed the gap in the metal panels panels that are nailed on to the wood frame, Then nailed the welting on to that 1" strip of exposed wood
I don't really think it was done like that at Briggs, not from the original photos I have seen or the 60b that I have. The first picture looks correct.
John Cochran
juke joint johnny is offline   Reply With Quote
