Old 04-24-2017, 10:22 PM   #1
The Eclector
The Eclector's Avatar
Default Top radiator tube is oval and dented
I have a top radiator tube on my '30 Model A that has a persistent leak. Have replaced the hose and used Permatex #2 between the hose and the tube. With the hose removed, the connector tube is dented and a bit out of round which I suspect might be from over zealous tightening of the hose clamp. Is there anything I can do to straighten out the top tube?
Steve A.
Chicago, IL
1923 Ford Model T Depot Hack
1924 Dodge Bros Roadster
1929 Franklin 130 & 135
1930 Ford Model A Speedster
1932 Detroit Electric
1939 Ford V-8 Deluxe fordor
1946 Chevy 3600 Pickup
1948 Chevy Fleetmaster Sport Coupe with Wood Kit
1950 Studebaker Champion Starlight
1953 Dodge B4B pickup
1963 Chevrolet Corvair Spyder convertible
The Eclector is offline   Reply With Quote
Old 04-24-2017, 10:26 PM   #2
Fred S
Fred S's Avatar
Default Re: Top radiator tube is oval and dented
I used a exhaust pipe expander from Harbor Freight to make mine round again. Be gentle.
As I expanded it, I tapped on it lightly with the side end of long socket extension.
Fred S is offline   Reply With Quote
Old 04-24-2017, 11:26 PM   #3
Mike V. Florida
Mike V. Florida's Avatar
Best bet.
Old 04-25-2017, 10:41 AM   #4
AL in NY
AL in NY's Avatar
I inserted a short piece of exhaust pipe into the radiator top and bottom tubes to strengthen them and make them round again. The exhaust pipe outside diameter needs to match the inside diameter of the radiator tubes. I left them in, so I can tighten the hoses better. No leaks ever.
AL in NY
AL in NY is offline   Reply With Quote
Old 04-25-2017, 01:26 PM   #5
rocket1
Stainless tube would be better if you can get short pieces,try muffler shops,no rust.
rocket1 is offline   Reply With Quote
