Carburetor Question: Can you use a Single Venturi with an Inside Diameter of 0.675” (Typical is .845” ID) on a carburetor designed for Double Venturi, or should the .875” ID be used?
I am working on a 1930 Tudor which came with a Zenith carburetor which needed some work (GAV would not turn). This carburetor still worked and ran the motor acceptably. In the mean time I purchased a used/rebuilt carburetor (Zenith 2, Black in attached Photo) off Ebay and it worked fine. Disclaimer: My first time at rebuilding a Zenith. I cleaned everything, purchased all new jets, GAV, and gaskets. I installed on my good running car with bad results, very rich and black smoke out the tail pipe. I experimented by swapping the bottom assemblies (My original rebuilt Zenith top and Zenith 2 bottom) and low and behold the car ran great, thus my conclusion was my lower half rebuild was not quite right. Upon investigation of the two lower halves I see some differences and was hoping you experts might chime in here. I believe the carburetor that came with the car is an early Zenith 1 double venturi bottom with the cast iron well, with no threads or provision for a brass well. Also note the positions of the main and cap jets for the double venturi, and the small bowl vent hole. The attached photo shows both bottom halves; the Zenith (Gray, with the old jets shown), and the Zenith 2 (Black). The Zenith has NO secondary well, and no place for one (no threaded hole) with a Single Venturi Inside Diameter 0.675” (outside has a recess machined in shoulder) and Cap and Main Jet are on centerline of the carb body. All the jets I removed had numbers, Cap 19, Main 20, Compensator 19, the new jets have NO numbers. As I stated, before I took apart it did work. The Zenith 2 Single Venturi, Inside Diameter 0.845” and Cap and Main Jet are slightly offset. Other then that I cannot see any difference; I have read on the Model-A.org site that the Single Venturi should be 0.845. I am not sure what is wrong my lower half yet however it did run before so I hope to get it assembled and running correctly again. Any help/direction would be great. Thanks Scott Last edited by scokeing; 11-23-2010 at 10:11 PM. Reason: Add picture |
The upper carburetor was (is) a double venturi style. The 0.675 venturi might have been made for a special commercial application, but it would not work well with your car. It is OK to use the common 0.845 venturi in place of the original double venturi.
The main jet in the double-venturi carb. (the one with the small hole) originally had a bullet shape to the top. If that is what you have, it might be original. That style is very rare, so be sure to save it if you do not keep it in your carburetor. Repro jets with the bullet top are slightly different in shape. |
Thanks for the info Richard, I added a photo of the jets I removed from the Double Venturi carburetor as well as the Single venture used in this application, not sure if you can tell from this view if they are original or not.
I have often heard that the repo jets are often not the correct size, and folks just buy them, install, and then the car does not run well. In many cases they need to be soldiered shut and carefully drilled out to the correct size, or try and find some original jets. Something to consider!
I have never seen original jets with a bullet shape. A single venturi will not work correctly in a Double Venturi carburetor. The compensator jet, idle jet, and cap jet in a Double Venturi are different than the later jets.
You might refer to the Service Bulletins as they cover the changes to the carburetors, jets, and secondary wells of which there are 3 types. Ron |
