Could somone tell me the number for the points, that we could buy at O'Reillys? i think that was on the Barn not to long ago;
Thanks Bill |
What style ?
A123 they can look it up on their computer :-)
Thanks Guys !!
BWD a123 from past post good luck :-)
Not the newer ones from 1970's.
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask |
#7 | |
![]() Quote:
I could not tell from the photo online if this set includes the adjustable (screw-in) point that goes opposite the points arm. Has anyone used these that can confirm? Thanks.
Jim Cannon Former MAFCA Technical Director ![]() "Spread the Joy! Have a Model A day!" |
I am using a set of these points.
They came with the original style screw-in opposing contact and a small capsule of cam lube.
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62 Last edited by 1955cj5; 08-17-2016 at 07:03 PM. |
And open the box before you get out your wallet...the tiny stationary point can easily weasel its way out past the flaps leaving you with a brand new half set.
I looked that up...It shows half a set, just the movable point. (A123)???
Mike Stitt "A business that make nothing but money is a poor business." -Henry Ford |
As 1955cj5 said. They come with everything including a small capsule of lube. I purchased two sets to have a spare. I found they didn't align well without modifying the upper plate. I had to adjust the points every 80 miles as the wear block was wearing down making the point gap too close, causing poor starting and running. Tried two sets with same outcome. Have others had good luck?
1930 Pickup in Prior Lake, MN |
#13 |
Points requiring adjustment after 80 miles is absolutely ridicules. I bought one set from O' Reilly and returned them the next day. Made in China and completely junk. NAPA cost more and are of good quality even if made in Mexico. (Standard)
#14 |
China parts. Pure junk.
Mexican made parts, pretty good quality stuff from my experiences. Most Motorcraft electrical stuff comes from Mexico as does John Deere's electrical components. Never had a problem with any of them. |
#15 | |
![]() Quote:
The set I bought through O'Reilly's were made in Mexico.... Luck of the draw I guess...
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62 Last edited by 1955cj5; 08-17-2016 at 07:29 PM. |
#16 |
Yes, the ones I have are made in Mexico too. Same box that 1955cj5 has. I would still like to find some that are good and will hold up. Meanwhile, I switched over to the modern points set up by changing the upper and lower plates.
#17 |
Mine have been in there for a few hundred miles....but sometimes I just go out in the garage and check this and adjust that, and the points may have been re-set.
I did buy a new distributor cam. My old one was a little rough and worn...
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62 |
#18 |
#19 |
The good ones are A123 and you can get them under the "Standard" name FD1718. I think the standard brand might be NAPA. Both are good quality with a great wear block.
#20 |
For what it's worth, Rock Auto carries Model A points made by Standard and A/C Delco.
