I'm going run 4 Stromberg 48 carbs on my 471 blower what would be a good jet size to start with it will be straight linkage 293 flathead
Start at around 52-54 and go with bigger PV also. Avoid being too lean. Better to back off slightly after testing than discovering a expensive problem while trying to get big enough. There is a very wide range of A/F mixtures where the engine will run. As you get closer to semi-perfect it becomes more and more difficult to determine which way to go without measurements. Better a little rich for safety. Some of where to establish the jetting is influenced by how the engine is to be used. It will be different for maximum competition performance than for cruising around on the street.
OK thanks will do
Get an air/fuel meter.
Are you talking about the ones you run in the exhaust
Knock knock...
RIP Tyler... My Son, Helper & Best Friend. Feb '78 to Father's Day '10. www.97-express.com ~ [email protected] |
yea sir
how much bigger on the pv would you think to go
The power valve size is ass-backward from the main jets. The smaller numbers indicate LARGER orifice sizes. Something in the 50's size range is where I would start.
31,
I seem to remember some guy in Utah who actually attends Bonnevile and real world sets up Strombergs on site........Uncle somebody........might be Uncle Max, 801 301 6114 .......801 583 6169........and that's no jive. Charlie ny Last edited by Charlie ny; 08-13-2016 at 08:29 AM. Reason: aded space bet ph#'s |
thanks for all of your help JWL I will have a place to start from
#13 |
JWL always has good advice and Uncle Max can take care of your needs and offer good advice as well.
#14 |
sent couple pm to max and never herd back yet
