Old 06-09-2015, 05:45 PM   #1
Neil Mylar LakewoodCA
Neil Mylar LakewoodCA's Avatar
Default Old Model A homemake trailer hitch
I'm removing this from my 1928 Tudor.
As you can see, it took the place of the rear spring hold down brackets.
To use the hitch, the rear tire would have to be removed.
The spare tire bracket would not need to be removed. I only removed it to replace a stripped stud.
I purchased the new trailer hitch that bolts between the bumberettes.
With the new design, I'll be able to carry a bike rack and tow a trailer, if I ever need to.
I may sell or trade the old hitch, if anyone is interested.
Neil
[email protected]
Neil Mylar LakewoodCA is offline   Reply With Quote
Old 06-09-2015, 06:33 PM   #2
barkleydave
barkleydave's Avatar
Default Re: Old Model A homemake trailer hitch
Which hitch did you purchase? How wide is it. I am looking for a solution for my truck.
The one you took off is interesting but not for my application.
barkleydave is offline   Reply With Quote
Old 06-09-2015, 09:01 PM   #3
I purchased the Wagner hitch
St. Louis, MO.
314-966-4444
Cost $249.95, plus shipping.
It takes the place of the rear bumper cross piece.
The inside lip is 29 1/4 inches.
I have not installed it yet, but it looks quality and heavy duty.
Old 06-10-2015, 01:05 AM   #4
CarlG
CarlG's Avatar
I have the Wagner hitch on my PU. Easy installation (15 minutes), very well built.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 06-10-2015, 06:03 AM   #5
Rex_A_Lott
In the third picture the sticker says, " For display of flag hitches only, not intended for towing".
What is a flag hitch? I dont know that term.
Thanks
Rex_A_Lott is offline   Reply With Quote
Old 06-10-2015, 06:46 AM   #6
barkleydave
Not dot approved
Old 06-10-2015, 09:07 AM   #7
CarlG
CarlG's Avatar
John LaVoy had a nice write-up in Model A Times a while back. It not only will pull a trailer nicely, but Wagner also has a device that will plug into the receiver that will hold flag(s) for use in parades, etc. The flag part will work with any 2" hitch receiver.
I would not hesitate to tow a trailer with this hitch, certainly much more than one I would piece together, which wouldn't be DOT approved either.
Alaskan A's
Old 06-10-2015, 06:51 PM   #8
1931 flamingo
1931 flamingo's Avatar
If you go by the label that's a lot of money just to hang flags...............................
Paul in CT
Old 06-28-2016, 03:18 PM   #9
Bruce
Bruce's Avatar
Wagner Products doesn't trust you guys NOT to "Desi Arnaz" a 40 footer full of rocks over the Continental Divide!
Bruce is offline   Reply With Quote
Old 06-29-2016, 08:44 AM   #10
barkleydave
I like the Wagner but I measured my CCPU and it is not wide enough. I need approx. 42 inches. Darn
Old 06-29-2016, 09:33 AM   #11
Jerry in Shasta
Jerry in Shasta's Avatar
Does the Wagner hitch attach to the body or to the frame?
Towing a load with the body as the control and power point could be a disaster in an emergency. Like the trailer jack-knifing up along the car and twisting the body off the frame.
Connoisseur of Rust
Jerry in Shasta is offline   Reply With Quote
Old 06-29-2016, 09:47 AM   #12
CarlG
CarlG's Avatar
Originally Posted by Jerry in Shasta View Post
Does the Wagner hitch attach to the body or to the frame?...
It attaches to the bumper supports, which are then attached to the frame. The hitch actually replaces the bumper spreader bar. There is a "U" shaped channel on each side that encases the bumper supports and supplies vertical support for the hitch when installed. Look closely at the pictures in post #3 above.
Alaskan A's
Old 06-29-2016, 09:53 AM   #13
CarlG
CarlG's Avatar
It's designed to replace the bumper spreader bar. Since Pickups never had a rear bumper, you would have to add these brackets. I had already installed a rear bumper on my CCPU, so it was a no-brainer to install the Wagner Hitch.
Alaskan A's
Old 06-29-2016, 12:11 PM   #14
Tom Wesenberg
Tom Wesenberg's Avatar
Back in 1967 my neighbor attached his trailer hitch to an 8" round plate he made for the trunk floor of his Barracuda. He then used this light car to tow a heavy enclosed 4 wheel trailer full of building supplies. One day a large hole appeared in his trunk floor and his trailer and car parted ways.
