For some reason I started getting a rather loud rattle from what sounded like the top of the drivers door which turned out to be the rod connected to the open handle on my 31 Tudoor .
There are numerous ways to go at this , maybe some more desirable than the small rectangular pieces of an old credit card I curled between the rod & door & held in place w/ a drop of super glue . I hope the judges don't notice ! ![]() |
If you use a vintage credit card the judges will not take off any points.....
A couple felt pads glued to the door skin should keep it quiet.
I think I have that problem also. I assume you have to remove the door panel to fix this?
Richard |
#5 | |
![]() Quote:
If you have the aluminum upper door seal held down by the garnish , don't let it fall down in the door or then panel removal is req'd . I fastened my 4 door seals w/ dabs of Goop prior to the garnish to prevent that --great stuff for a lot of things . |
Richard |
