Old 04-20-2016, 06:23 PM   #1
John Duden
John Duden's Avatar
Default Remachining a highspeed speedometer drive for a truck
been tinkering with this today, a 28-29 AA truck with the highspeed wormdrive. for the gear on the drive shaft that is stamped 5 1/6-1-32x6 i made a driven gear for it. Since the driven gear has 19 teeth i took one from a car that had 19 teeth. I had a junk 6.6-1 slotted driven gear so i turned the gear off the shaft and took it down to .351, the car gear has an ID of .350 so it made a good press fit. the OD of the gear was still a little big so i turned off .030 off the diameter. one could do this with a nylon gear if they are worried about wear on the driveshaft gear.
I was lucky enough to be able to find the drive shaft gear but i could not locate driven gear.
File Type: jpg 9f147b58-5267-4fd5-9844-b12c015d2a95.jpg (27.1 KB, 20 views)
John Duden is offline   Reply With Quote
Old 04-20-2016, 07:16 PM   #2
Mark in MT
Default Re: Remachining a highspeed speedometer drive for a truck
Good work, let us know how it works. Necessity is the mother of invention!
Mark in MT
Always looking for another opportunity to be wrong.
Mark in MT is offline   Reply With Quote
