Old 04-15-2016, 04:46 PM   #1
rusty12
Default Is a 1932 Pickup Chassis the same as a passenger car?
I just ran across a real nice, stock 1932 Model B pickup chassis. Unfortunately, the body and bed were removed for a street rod years back. The chassis is complete with all the mechanicals as well as the hood, grill, fenders, etc.
My questions is: Will a stock 1932 passenger car body fit on this chassis? Thank you in advance.
rusty12 is offline   Reply With Quote
Old 04-15-2016, 04:50 PM   #2
deuce lover
deuce lover's Avatar
Default Re: Is a 1932 Pickup Chassis the same as a passenger car?
Yes.Commercial grill is different.
Old 04-15-2016, 06:59 PM   #3
DavidG
DavidG's Avatar
Unless it was one of the hyper-rare deluxe pickups.
The rear spring will have more leaves in it than any used for passenger cars so you'll need to either replace it or remove some of the leaves.
Old 04-15-2016, 08:04 PM   #4
GSCOV
more leaves than a station wagon?
GSCOV is offline   Reply With Quote
Old 04-15-2016, 10:22 PM   #5
DavidG
DavidG's Avatar
Ford classified the station wagon as a commercial vehicle, not as a passenger car. Early '32 commercial vehicles had 12-leaf springs and later versions had 13-leaf springs. The most in a passenger car chassis was 11 leaves for the Fordor sedan.
Old 04-16-2016, 05:23 AM   #6
my4dv8
Well you lucky son of a gun. Get it and start a new project. If you don't need it send it our way.
my4dv8 is offline   Reply With Quote
Old 04-18-2016, 12:55 PM   #7
jerseyboy
jerseyboy's Avatar
Dave,
Will the steering column angle need to be adjusted?
Keep V-8ing and 4-banging!
She just don't have the appetite
For gas somehow,
And Dad, I got four carburetors
Hooked up on it now.
I tried to hook another
To see if I'd do a little good,
But ain't no place to put it
'Less I perforate the hood.
Wanted, lower side sections of 32 radiator cowl.
jerseyboy is offline   Reply With Quote
Old 04-18-2016, 01:31 PM   #8
DavidG
DavidG's Avatar
Great catch, Scott! Depending on the vintage of the steering gear, the sector housing and the sector arm will have to be replaced for passenger car use. If it is a late chassis, only the sector arm will require replacement.
Another difference is that while the front fenders are common with passenger car fenders, the rear fenders on a pickup are not shared with any other '32 body type.
Old 04-19-2016, 02:44 PM   #9
Kahuna
Kahuna's Avatar
Hi David
Not knowing much about the pickups, what is different about the steering?
Thanks
Jim
Kahuna is offline   Reply With Quote
Old 04-19-2016, 03:13 PM   #10
Bruce Lancaster
Steering column is closer to vertical, because pickup cowl is shorter than passenger and so distance from firewall to dash is shorter. Early in the year pickups had different sector housing castings with holes placed to tilt up the column, later in year some genius thought to make holes in frame slotted so same steering box castings could be used in both!
Old 04-19-2016, 03:59 PM   #11
DavidG
DavidG's Avatar
As Bruce says. The late change left only the sector arm different between the two versions.
Old 04-19-2016, 07:21 PM   #12
Bubsyouruncle
And much of the difference is explained in the reprint of the 32 service manuals, available from many vendors.
Bubsyouruncle is offline   Reply With Quote
