Old 03-02-2016, 09:46 AM   #1
FrankWest
FrankWest's Avatar
Default Installing new firewall Choke Grommet
I need to install a new firewall choke grommet.
I want to remove the coke Knob, How does that come off the end of the cable?
FrankWest is offline   Reply With Quote
Old 03-02-2016, 10:07 AM   #2
DavidG
DavidG's Avatar
Default Re: Installing new firewall Choke Grommet
If your four-cylinder choke cable is original, the knob attachment was intended to be permanent and even if you could remove it, there's the threaded escutcheon on the dash that would prevent you from passing it through the hole in the dash. In other words, the choke cable can only be removed by detaching it at the carburetor and pulling it rearward through the firewall and dash.
Old 03-02-2016, 10:28 AM   #3
FrankWest
FrankWest's Avatar
WOW! Great to know! Glad I didn't try to muscle anything. I learned to always ask because I don;t want to demolish my car. Thanks again! photo below. There is a small copper tube that goes into the choke hole and is attached to the intake? I don't know what the is for? Something from the old heater installation?
Old 03-02-2016, 01:50 PM   #4
DavidG
DavidG's Avatar
That tube is a vacuum line to operate the windshield wiper motor.
Old 03-02-2016, 01:52 PM   #5
FrankWest
FrankWest's Avatar
Was it originally designed to go in the choke firewall hole?
Old 03-02-2016, 02:18 PM   #6
DavidG
DavidG's Avatar
Yes.
Old 03-02-2016, 07:03 PM   #7
1931 flamingo
1931 flamingo's Avatar
Frank: Instead of pulling everything apart, it's a lot easier to cut the new grommet on an angle and slip it over the cable/tube and insert into the f/wall. Put the slice on the bottom. FWIW
Paul in CT
Old 03-02-2016, 07:46 PM   #8
DavidG
DavidG's Avatar
Good advice, 1931 flamingo, but the slice should be at the top otherwise the weight of the choke cable and vacuum tube will open up the slice.
Old 03-02-2016, 08:18 PM   #9
FrankWest
FrankWest's Avatar
Good advice
I was thinking of doing that too..I was going to add some 3M black weatherstripping adhesive to the cut portion, to glue it back together. But you are right as long as it is along the top not problem there. My vacuum line has medical tape on it, I guess it was injured. My windshield wiper only moved a little. No problem, I was going to use rainx anyway and for that matter I was not really planning to drive in the rain. But I would still like to get the wipers working.
Old 03-02-2016, 10:30 PM   #10
325w
A little dab of super glue will work and not be as messy
325w is offline   Reply With Quote
Old 03-03-2016, 07:44 AM   #11
FrankWest
FrankWest's Avatar
Thanks
Old 03-03-2016, 11:16 AM   #12
glennpm
glennpm's Avatar
I've also done this with a cut and then super glue back together as 325w mentioned.
Old 03-03-2016, 12:27 PM   #13
FrankWest
FrankWest's Avatar
Super glue is better..less noticable!
Thanks for you Tip!
