Old 10-25-2015, 03:52 PM   #1
Jim
Default resister
What ohm resister is needed on 57 272 ignition? Also what voltage is needed at the plus side of the coil. Thanks very much. Jim
Jim is offline   Reply With Quote
Old 10-25-2015, 05:48 PM   #2
dmsfrr
dmsfrr's Avatar
Default Re: resister
I've got 3 new replacement ballast resistors and checked them with a Fluke multi-meter:
1 was 1.5 ohms, 2 were 1.7
I also have an older and well used OEM ballast resistor, it measured 1.9 ohms.
Running voltage (not 'starting' voltage) at the coil + terminal should be 8 to 10 volts.
Starting/cranking voltage will be 12v at the coil.
Old 10-25-2015, 07:09 PM   #3
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
1.5 to 1.9 is ok.........
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
