Old 12-27-2015, 04:55 PM   #1
eystein
eystein's Avatar
Default Anti-freeze Separation ?
Checked the anti freeze at the top of the radiator and to my surprize it was only holding down to +5 deg F. So I decided to drain off some coolant from the drain cock at the bottom in order to make room for filling more anti freeze, but to my surprise I saw that the half gallon that I drained off was deep blue in color. When I measured the freezing point of what I drained off at the bottom, I discovered it was good for -58 deg F.
I then poured what I drained off at the bottom back at the top of the radiator.
The car then sat for two weeks, and now its the same story again. -4 deg F freezing point at the top of the radiator and -58 deg F at the bottom.
How can this be? Does the anti-freeze separate from the water over time and can the engine freeze up at the top while it is protected at the bottom.
eystein is offline   Reply With Quote
Old 12-27-2015, 06:49 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Anti-freeze Separation ?
I've never heard of this happening before.
What brand or type of antifreeze are you using?
Old 12-27-2015, 07:23 PM   #3
Tomy Turbos
Antifreeze is completely hygroscopic. The two substances combine into one.
The only way this can happen is that they were added separately and then left uncirculated.
You didn't say if the car has been run for any length of time in the meanwhile. If it hasn't, therein lies your problem. If it HAS, look to the T-Stat and then the Water Pump.
A 'backyard' test is to take the T-Stat out of the car, run it up to Temp, then shut it off with an electric fan in front of the Radiator, thereby causing a thermosiphon which will force the fluids to circulate. Then re-test.
While you're waiting, toss the T-Stat in a small pan on the stove along with your spousal-unit's kitchen thermometer to see if it starts to open at the specified temperature.
If the T-Stat works and it's not circulating, you need a Water Pump or you have MAJOR blockage.
There are only two kinds of cars: Those that need fixed and those which are going to.
Tomy Turbos is offline   Reply With Quote
Old 12-27-2015, 07:40 PM   #4
Pinesdune
Pinesdune's Avatar
It should never seperate, no matter how old or what ratio of water/antifreeze mix. Drain it immediateley!!! I don't know if your car sits outside or whatever, but in Norway you can pretty much have the same weather as Canada from what I've heard, and I wouldn't want to risk cracking the block if the power goes out for a day and in the rush the car gets missed. You can watch it for seperation in the pails too once you've drained it.
Pinesdune is offline   Reply With Quote
Old 12-27-2015, 07:42 PM   #5
Mitch//pa
I'm wondering what your using that's a deep blue? Also is it full strength or 50/50
Old 12-27-2015, 09:14 PM   #6
MikeK
MikeK's Avatar
That blue antifreeze is likely a phosphate based OAT engine coolant specified by some Asian vehicles. It is an extended life formula but may suffer breakdown separation if either the pH goes awry from leaking combustion gasses or by adding any of several non-compatible substances such as IAT coolants containing amines, Na-silicates (leak sealers), or adding water pump lubes (soluble oils).
First, check for leaking combustion gasses into the coolant. If none, flush it out, switch to a simpler ethylene or propylene glycol based coolant. Don't add any "snake oils" to it and you should be good for extended storage without the density separation issues.
MikeK is offline   Reply With Quote
Old 12-27-2015, 10:48 PM   #7
Gold Digger
Four years ago I bought 2 fifty-five gallon barrels of anti-freeze from a distributor to put in all my dozers and equipment. The next year I checked the freezing point and was surprised to find out it was only good for 10* above. I first thought someone had stolen my antifreeze and filled up the radiators with water. I went back to the distributor and told him about it and he informed me that it was only good for one year. He called it seasonal antifreeze I had bought. He said I needed permanent antifreeze. Now days I only buy Preston brand full strength.
Gold Digger is offline   Reply With Quote
Old 12-28-2015, 12:50 PM   #8
eystein
eystein's Avatar
Well, neither have I seen this before either. So I was really surprised. I think that even if the solution had not been agitated by running the engine after the last time I filled the system, the mixture should still have evened itself out given several weeks time.
Anyway, here is the link to the antifreeze data sheet. I cant see anything peculiar from that.
http://www.biltema.no/BiltemaDocumen...361784_TDS.pdf
Old 12-28-2015, 12:59 PM   #9
Tom Wesenberg
The link won't open for me.
Old 12-28-2015, 03:59 PM   #10
eystein
eystein's Avatar
Try this link
Old 12-28-2015, 04:06 PM   #11
MikeK
MikeK's Avatar
Thank you for posting the link! The TDS (technical data sheet) link definitely confirms it is an OAT type antifreeze! Their equilibrium is often very sensitive to changes in pH and contamination. If you didn't put any additional additives into it, then the buffer in the coolant, set to maintain pH 8.0-9.0 was likely expended. I suspect a head gasket leaking exhaust into the water.
