Old 05-14-2015, 02:59 PM   #1
Richard/Ca
Richard/Ca's Avatar
Unhappy rear main cap
Will today I took my rear main cap off and it has a chunk broken off where the seal goes. I have the broken piece so that is no problem. Last week the motor over heated and filled the pan with water. Would the broken part cause the water leak.And any suggestion on how to replace the cap? Motor is still in car.
Richard/Ca is offline   Reply With Quote
Old 05-14-2015, 05:04 PM   #2
Joe K
Joe K's Avatar
Default Re: rear main cap
Pix would help a LOT.
Joe K
Shudda kept the horse.
Old 05-14-2015, 06:34 PM   #3
colin1928
colin1928's Avatar
As there are no water jackets near the rear main bearing cap
I think you have 2 different issues
colin1928 is offline   Reply With Quote
Old 05-14-2015, 06:36 PM   #4
1931 flamingo
1931 flamingo's Avatar
I think you've got bigger problems than a cracked cap. Overheating (usually the water goes out the overflow or out around the radiator cap) and filling the pan (I assume you mean the oil pan) doesn't compute.
More info needed and/or pics.
Paul in CT
Old 05-14-2015, 07:09 PM   #5
Mikeinnj
Mikeinnj's Avatar
That seal controls oil not water. Sounds like a head gasket issue and cap repair or worse.
Mikeinnj is offline   Reply With Quote
Old 05-14-2015, 07:23 PM   #6
glenn in camino
glenn in camino's Avatar
When I first got my unrestored AA flat bead I thought I'd adjust the bearing clearances, so I removed the rear main cap. As I lowered it down, a piece of babbit, the size of a quarter came out. Not wanting to rebuild the engine at the time, I stuck it back in with some red Locktite and put it back together. I then drove it for another 8 years, expecting it to fall apart at any time, but it never did.
Old 05-14-2015, 08:12 PM   #7
Richard/Ca
Richard/Ca's Avatar
I will try to post pictures. Also when I put the head on I only used the spray on copper seal on the gasket and the Head and block.
Old 05-14-2015, 08:24 PM   #8
My1930ModelA
Richard, I also just ran into a problem today when I removed my rear main cap. A portion of the babbitt on the forward thrust surface broke away. I have the piece and it fits perfectly into the area where it broke out of. Thinking of JB welding it back into place as it is captured and held in place anyway when the cap is installed. Good luck with your car and I hope you find a solution.
Mark
My1930ModelA is offline   Reply With Quote
Old 05-15-2015, 06:29 AM   #9
Mark W.
Mark W.'s Avatar
I'm no expert on old Babbitt, but I had the same problem and went to a full rebuild including new mains.
My .02 is that if it is beginning to go, it will continue to go. I'll stick with the old STP ad - Pay me now, or PAY me later...
Mark W. is offline   Reply With Quote
Old 05-15-2015, 01:56 PM   #10
Richard/Ca
Richard/Ca's Avatar
OK! Thanks everybody. I was thinking (omg) about emailing Bob Barlow in Oregon to see if he could pour me another main baring cap. If I sent the broken one and another good one to use.
Old 05-15-2015, 04:43 PM   #11
CarlG
CarlG's Avatar
Bob Barlow works miracles on main caps. A half dozen or so in our club will attest to that.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 05-15-2015, 05:06 PM   #12
Kohnke Rebabbitting
I thought that was his brother Bill?
Kohnke Rebabbitting is offline   Reply With Quote
Old 05-15-2015, 05:19 PM   #13
CarlG
CarlG's Avatar
I stand corrected, Bill it is.
BABBITT WORK
1. No known website: Bill Barlow (541) 389-2694 (Oregon) [email protected]
Alaskan A's
Old 05-15-2015, 05:13 PM   #14
Richard/Ca
Richard/Ca's Avatar
Thank you CarlG I tried calling him so I could better explain what the ploblem is phone was busy.I will try again later. I think it would be better then email.
Old 05-16-2015, 02:51 AM   #15
Richard/Ca
Richard/Ca's Avatar
My bad I type in Bob instead of Bill. Sorry!
