Old 03-26-2015, 06:01 PM   #1
Thirtyeight
Thirtyeight's Avatar
Default 38' Rear Tail Pan Dimension Question???
I recently installed a new repro tool box and tail pan on my 38' Conv. and I would like to put the rear bumper back on. But, what I don't know is the location and dimensions of the two slots for the bumper brackets and I would like to get this right.
Any help would be greatly appreciated.
Thirtyeight is offline   Reply With Quote
Old 03-26-2015, 07:18 PM   #2
cmbrucew
cmbrucew's Avatar
Default Re: 38' Rear Tail Pan Dimension Question???
38
This topic was discussed last month I believe.
Check the archives.
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
Old 03-26-2015, 08:31 PM   #3
johnny
I am temping to send you a picture of the measurements you need if the picture method does not work, I will list the measurements for you. I can't seem to get the picture to work .So here are the measurements these are the finish sizes ,the cut out should be about 3/8 less for each side to allow for a flange to bend in So from the outer edge of the panel,1 3/8 to 1 7/16 in, 5 inches up from the bottom edge to the top of the opening which has some round to it . the finish opening is 1 3/8 wide . the measurement down from the lower bead to the top of the opening should be 3 1/2 inches.I will keep working on the picture also . Is your car the club or rumble seat model .If it is a club model I need information of the rear quarter filler panel, it fits behind the armrest and from the door striker post back to the seat. John. [email protected]
johnny is offline   Reply With Quote
Old 03-27-2015, 10:38 AM   #4
cmbrucew
cmbrucew's Avatar
https://www.fordbarn.com/forum/showth...er+irons+holes
38
Here is a thread that should help.
Bruce
Works good
Lasts long time
Old 03-27-2015, 06:39 PM   #5
swoopNZ
MEMBER EMERITUS
3 feet ( 36 inches ) from center to center, between the top of the slots on my 38 and 39.
swoopNZ is offline   Reply With Quote
