A video on Youtube features Les Andrews giving a talk on timing. Thinking I know it all, I ignored it at first. Then on a whim I decided to check it out. As he was talking about "Setup", he mentioned making sure the notch in the back of the distributor body allows full retard and advance of the spark lever. Today when I rechecked my timing (about once a year for me), I checked this for the first time. It was way off! I was only getting about half the travel I should have. After adjusting the steering column properly, something I didn't know I could do having owned a '28 for most of my life, and retiming the car, I can't believe how much better it runs.
Forty horses is plenty. |
The notch opening width allows for 20 degrees of movement.
that is a basic check that everyone should be aware of. it is mentioned in most how to timing tutorials
Here is the link for the Youtube Timing Video by Les Andrews
http://www.bing.com/videos/search?q=...0B82A87D3854D3
1931 160B & 1931 68B If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time? |
Yep, beginning with my web site in 1998. Les was a master at gathering info from outside sources!
http://www.abarnyard.com/ |
Full down on spark lever is way too much for any engine at 40 degrees. |
Since there are variables in the system when the timing is set, I feel the best way is to bring down the lever until there is no noticeable increase in the engine RPM for a set MPH.
I agree with Mike and set mine at about 28 to 30 degrees while cruising 45 MPH on the level. This is a totally stock engine.
I'm doing the same thing. I just run it at about half down on the spark lever during in-town driving, and when I get on a long straight I pull it down until I notice no additional power or rpm.
Since stock A's don't have self-advancing timing, the trick for me is to decide how to set the timing on hills. I'd like to get the max power, but as the car slows down the rpm is changing and ideally the timing would change. Unless the hill is long and steady climb, the engine rpm's are changing too often (deceleration, shifting) to adjust to.
Yeah! How about that! If you told a modern mechanic "Well, I adjusted my steering column today to get more spark advance!" They would wonder what planet you're on.
Terry |
Like telling an old timer mechanic to just burn a new program onto the memcal with UV light , easy as pie.
#13 | |
![]() Quote:
Tom... |
