Old 12-08-2014, 03:18 PM   #1
mrtexas
mrtexas's Avatar
Default Best way to install engine
Should I attach the part that mounts the starter to engine first or to frame first?
mrtexas is offline   Reply With Quote
Old 12-08-2014, 03:23 PM   #2
Mitch//pa
Default Re: Best way to install engine
attach flywheel housing to engine. use sealer at rear of camshaft on both sides of the gasket. dont forget the top shims..
Old 12-08-2014, 04:12 PM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
And after you install the flywheel housing and flywheel, be sure to mount the engine in your engine stand with the front down, then dial in the flywheel cover. Check it at 9, 12, and 3 o'clock positions. It should not differ by more than .006"
Old 12-08-2014, 11:38 PM   #4
Purdy Swoft
Purdy Swoft's Avatar
I've always done them like Mitch says. The other way may work and be easier to fit between the rear mounts but the transmission and rear end would have to be removed.
