Old 08-05-2010, 10:37 PM   #1
'29wagon
Default other than ford green
this low cost green enamel i plan to paint my motor is a baked on enamel once the motor gets hot enough, right?
now if i have anything i choose not to paint ford green and wish to antique, say using a blackening system (phosphoric based) what would be recommended for clear as a protection for that finish, is a clear enamel what i should look for ?
'29wagon is offline   Reply With Quote
Old 08-06-2010, 07:14 AM   #2
RonC
RonC's Avatar
Default Re: other than ford green
use engine paint it is designed for high temps. You can get a "cast" color. I wouldn't clear coat the finish as it would probably peel and yellow over time.
RonC is offline   Reply With Quote
Old 08-06-2010, 11:32 AM   #3
J Franklin
J Franklin's Avatar
Why go to all the extra trouble and expense when the proper paint is readily available?
Old 12-01-2014, 12:31 PM   #4
C26Pinelake
Just curious, why not paint it the proper Ford green ! Wayne
C26Pinelake is offline   Reply With Quote
Old 12-01-2014, 01:42 PM   #5
Purdy Swoft
Purdy Swoft's Avatar
I agree with Wayne !!! if correct appearance is important, no clear coat over the engine green, Cast blast or other new cast look paint for the exhaust manifold, or the black used on the carb or other black parts. The only place that I would consider a clear finish would be on unfinished parts to resist rust but not a glossy clear. If you apply the colors with a paint gun and enamel type paint is used, a hardener could be added for durability. High gloss finishes look over restored on the engine. Also, No primer on clean cast iron parts. Cast iron has all of the tooth needed for paint retention . If primer is used and for some reason the paint was to peel it would stick out like a sore thumb. Just my thoughts.
Old 12-01-2014, 01:51 PM   #6
Charlie Stephens
I would buy only a quality paint designed for engines. Your reference to "low cost green enamel" scares me. If I wanted orange, I would buy a paint for a Chevrolet and so on for other colors. Note that the surface of the block is such that brush on paints work very well.
Charlie Stephens
Old 12-01-2014, 04:06 PM   #7
700rpm
700rpm's Avatar
Agree. Do it right and do it once.
I've also been told that multiple coats, even of the correct paint, let alone a clear coat or primer, can inhibit engine cooling, a situation we sure don't need to encourage on a Model A.
Ray Horton, Portland, OR
