Hi Everyone,
I'm new to this Forum so I'd like to introduce myself. My name is Josh & I just purchase a sweet little 1931 4 door Sedan a couple of weeks ago. It seems to be very original & it runs & drives. It's been a blast driving it around a getting a ton of head turns & thumbs up. I look forward to talking with everyone as I know you guys are all very knowledgeable about this stuff & im very new to model A's. Here are a couple of pictures of my car. Here's my questions. I have had a few issues with stuff plugging up the fuel valve at the bottom of the tank, in turn starving the car of fuel & causing it to stall out. I've had to unscrew the valve on the side of the road & poke the hole to free it of debris. Aside from that it's running great. I do have a couple of questions though. 1. Anybody know of an easy way to clean the tank without removing the whole thing? 2. I need to replace the top & I haven't been able to find any instructions on how to replace the type of top I have. I know a lot of guys just weld in a metal top, but I'd like to keep mine how it is so I don't have to paint the car. I like how the old paint looks. As always. Any info would help. Thanks Josh |
#2 | ||
Welcome and congratulations,
Let's get to the meat, Quote:
The last time place a filter in the valve and reinstall the valve. This is the filter to use; Gas Tank Screen for Fuel Shut Off ![]() Next Quote:
http://www.abarnyard.com/workshop/roofinstall-1.htm
What books do you have to be able to service and optimally drive the car?
May I suggest; 1. Les Andrews red book 2. Reprint of the instruction manual 3. Large size service bulletin reprint 4. Restoration guidelines and judging standards And there are a ton of others but these are my top 4 to start.
Excellent suggestions from Mike. I might add that although you don't want to remove the tank the reality is that rust is in the tank which is probably almost a given on the top of the tank down. So any draining and flushing is short term at best.
The only thorough solution is to remove for a thorough cleaning and then seal. Yes, it's a job and a task but will be ultimately necessary for a good clean fuel supply. I have done short term fixes but they all ultimately need to be done, so you might as well do so sooner than later Mikes suggestions are good . The service bulletins have a wealth of information of the details of the a mechanically and the background behind running changes. We are blessed in the Model A world to have so much excellent printed information. Read and take in as much as you can All the best and welcome to ownership of your A. Larry Shepard |
Josh
I might add that you post where you are located geographically so maybe someone in an A group nearby might be a source for you. Marc and Mafca have many chapters and regions with wonderfully helpful members. Get in touch with a local group if there is ind nearby Larry |
Great job posting photos right from the start! The sedan looks great, you've got a good one there. Have fun |
Congrats and wecome! Nice looking model A Catalogs are another source of good free information, I use Berts, Brattons, Synders. All good advice above! There are no dumb questions period
Now for that Junk plugging up the valve, rust or the dreaded tank coating? |
I was apprehensive about replacing my top but found it to be an easy job and would never recommend a metal top. Most all suppliers have top kits and the wood bows are available if needed. I believe that Tom Endy has an article about how to do it. Maybe someone can link you to the site.
John |
Hi Josh,
Welcome to the club! You have a very nice looking early 31 sedan. Is it a Townsedan by chance? The dome light would be over the rear window and it may/may not have a center armrest in the back seat. How is the wood in the body and doors? I will give a shameless plug for my club's videos. Go to MFACA and you can order a video from the Diablo A's about replacing the top on a sedan. It doesn't look hard just very time consuming. Mike
1930artdeco - Did you mean MAFCA?? I just checked their site and didn't see anything about replacing tops.
Josh - are you talking about a roadster convertible top or something else? |
Location: Here I am in front of Todd's Grocery in 1931 selling Grit newspapers
Hi Josh.....nice sedan....wish I could help you with those questions, I'm not a mechanic. If you had asked me about Grit, whitewalls or oil.....I could give you some first hand opinions.
![]() BTW...welcome to the Barn.
"Bullshit and Brilliance Comes with Age and Experience" "Hey Lady, ya wanna buy a Grit?" "If you don't learn to laugh at trouble, you won't have anything to laugh at when you're old" Will Rogers |
I like them Fordors and it appears you have a nice Briggs Town Sedan (Rear seat arm rests and cowl lights, etc.) Also appears you have California Plates? Please don't install a steel top.
There have been gas tank flushing threads in the past with some excellent suggestions from Tom W. and among others. Welcome to 'The Barn'. |
#13 |
Read about using vinegar. It is cheap but kind of slow to work, which is actually good. You can fill the tank with it for dollars.
Whatever you do DO NOT EVER USE A VACUUM TO DO ANYTHING INVOLVING GASOLINE. NEW GUYS HAVE BLOWN THEMSELVES, HOUSES AND OTHERS TO DEATH. THAT'S NOT AN EXAGERATION. |
#14 |
If you do a web search for Diablo Model A Club you will find the website for their club. On the left side of their web site page you will see "tech videos". Click on this icon and you will see a video,for replacing the top,of a 31Slant Windshield Top Replacement. This will not be exactly like yours, since yours is not a slant windshield Model A. However it will be a great help in replacing the top on your Model A.
#15 |
The secret of properly installing a new top it to get it stretched tight. The attached photo shows an installation in progress on a 30 town sedan. The owner built a wooden frame out of 2x4's and tacked the material to it. The frame was made larger than the top of the car. It was then set out in the sun all day (July, Southern California) Every hour of so the material was pulled tight and re-secured.
The frame and top material was then set down over the top of the car and tacked into place The weight of the wooden frame held it in the stretched position as it was tacked into place. Then the wooden frame was removed for the finish tacking. The top came out very nice. A word on caution on a town sedan. The wire for the dome light is located on the right side above the door post. We managed to drive a nail right through it and it blew the fuse. Fortunately the car did not have an interior headliner at the time and we were able to locate the fault and correct it. Tom Endy |
#16 |
Your pictures look to be lower central valley of California. I would recommend you locate the local model a club and attend a meeting. I also would think members would then be able to guide you on the top, and the fuel/tank issues.
By getting an experienced pair of eyes and some Guidance you can learn and avoid some of the mistakes we all have made. If you give out a location where you are I am sure a local club member will contact you in short order. Bob Last edited by Brentwood Bob; 04-09-2017 at 10:18 PM. |
#17 |
Hi Jim,
Sorry yes I did mean MAFCA, sometimes I think faster than I type. If you go there and go to the store and scroll down to the DVD section there is one for a 31 Murry fordor. Tom-That is a clever idea and I may borrow it when I do my top way, way, way, way in the future. Mike
#18 |
Josh Mike"s tip of the filter that goes into the shut off valve sure fixed my problem I had to stop every few miles and blow back thru the line after putting in the pencil fifter no more problems yesterday I took it out to see how it looked and it was clean as new. but I did drain out a little water and some rust from the bottom of tank. I think with that filter your problems will be over no need to take off the tank. nice car!
#19 |
Is that an original top, or an old replacement?
#20 |
Josh, congratulations on your acquisition. Think of fordbarn as a great collection of friends. I would recommend you consider installing a "dirty leg" before you use the filter. Do a search on fordbarn for good descriptions.
Best of luck, Ian |
