Old 09-05-2014, 11:37 AM   #1
jpeconsult
Default This doesn't look correct - possible motor mount issue?
I have seen other members' pictures of their engines and their engines line up better, when comparing the top radiator hose. It looks as though my engine has dropped in the back causing the wrong angle for the top radiator hose. Also, the fan blades are not at an equal distance from the radiator. As shown in the pictures, the top blade is approximately 1.25" from the radiator where the bottom blade is only .5" away.
Pictures are of the radiator hose alignment, fan (distance from radiator) and motor mounts.
Your thoughts or remedies are appreciated. --Jeremy
(Edit: forgive the side-shot photos)
File Type: jpg Radiator to Block with Fan Measurement.jpg (67.0 KB, 152 views)
jpeconsult is offline   Reply With Quote
