Old 05-26-2014, 06:48 PM   #1
LeroyM
LeroyM's Avatar
Default Doing bodywork; need pictures of two areas.
Hey guys,
I'm doing some bodywork on my 31 coupe. The usual patch panels and touching up some ruff areas. I need pictures of 30 and 31 coupes in two areas. One is were the windshield post, visor and roof meet. On my coupe there's a small gap or hole on each side, it's about the size of a pinky finger. Is this correct or what could be the problem?
The other area is where the door and cowl area meet. On mine after doing the patch panels the cowl area is about 1/4 of a inch lower on each side, but everything else lines up as far as vertical cowl band edge and alignment to the rear body line at the cowl area. I'm thinking this might be a shimming issue with the wood block at the cowl but not sure.
Any pictures of theses two areas or help would be appreciated.
Thanks.
LeroyM is offline   Reply With Quote
