Old 04-05-2014, 04:03 PM   #1
mshmodela
mshmodela's Avatar
Default water wetter
Looking for opinions on water wetter:
Appears Les Andrews has used it...
http://www.mafca.com/tqa_e_cooling.html
https://www.youtube.com/watch?v=pApWgZdozQA
mshmodela is offline   Reply With Quote
Old 04-05-2014, 04:36 PM   #2
machine girl
Default Re: water wetter
tried it in a couple of street rods, saw no difference, also not cheep.
machine girl is offline   Reply With Quote
Old 04-05-2014, 04:53 PM   #3
CarlG
CarlG's Avatar
My PU came from Southern California and had water-wetter in it when I bought it. The guy I bought it from was suppose to drain it and put anit-freeze in it for me, but didn't. Shipped it anyway. In February. To Alaska. You can no doubt finish the rest of that story!
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 04-05-2014, 05:36 PM   #4
29er
29er's Avatar
The use of what coolant to use is certainly not universal among Ford Barn members. Andy Wiedeman of the Rocky Mountain A's contributed to the discussion by his recent technical guide, "What coolant to use".
WaterWetter is discussed in detail in Section 5 beginning on page 27.
http://rmaford.org/wp-content/blogs....uids_v2007.pdf
Whether one favors water or year-round anti-freeze, I'm sure Andy's treatise will provide food for thought! Thanks Andy!
Mike in Or-e-gun
29er is offline   Reply With Quote
Old 04-05-2014, 07:15 PM   #5
Willie Krash
Willie Krash's Avatar
Mike in Or-e-gun
Mike, before I quick read your link I asked myself if a drop of soap in the radiator would break the surface tension (It will) and aid to cooling.
Just a thought.
Another Mike in Orygun, aka Willie Krash.
Mike Stitt
"A business that make nothing but money is a poor business."
-Henry Ford
Willie Krash is offline   Reply With Quote
Old 04-06-2014, 11:06 AM   #6
mshmodela
mshmodela's Avatar
Mike in Or-e-gun
Great white paper... it went will with my morning coffee..
Many thanks...
-Mike
Cleveland, Ohio
Old 04-06-2014, 01:20 PM   #7
29er
29er's Avatar
Mike (Willie Crash): You hit upon the primary reason proponents of Water Wetter (WW) give for using it: the stuff reduces surface tension of water, thereby reducing the size of air bubbles that form on the inside of the engine and allowing more of the coolant (water) to make contact with hot metal surfaces, thus increasing the capacity of water to carry away heat and lowering engine temperatures.
While there are data showing WW does indeed reduce water's surface tension (including Andy Wiedeman's paper), the amount by which temperatures are lowered varies. The manufacturer of WW (Red Line Synthetic Oil) claims a reduction of coolant temperature of "up to 20 degrees" (http://www.redlineoil.com/products.a...e=true&pcid=10). Others, writing on this and other car forums, have reported significantly less benefit.
Your observation of using soap to reduce water's surface tension should theoretically result in the same cooling benefit. After all, that's how soap works. But the results of using soap in a Model A engine are unknown to me. How much soap is required? What kind of soap? By how much would soap lower engine temperatures? Do soaps contain other chemicals that may be beneficial or harmful to a Model A engine? I don't know, but I don't think I'll experiment on my car.
Red Line claims another reason for using WW is its anti-corrosive properties. By itself, water is corrosive to cooling systems. So, those who use water usually recommend some kind of anti-rust treatment be added to the radiator. There are differences of opinion about the ability of WW to reduce corrosion. And, as seen from the posts above, many people cite their personal experiences that the stuff actually promotes corrosion.
For me, the jury's still out. I've been following threads on what to use as an engine coolant for some time. I'm a little skeptical of many engine additives and I'd sure like to see some test data on the corrosiveness of Water Wetter. So if Marco or James or anybody else can cite any technical reports, I'd be much appreciative.
Old 04-05-2014, 05:26 PM   #8
V4F
V4F's Avatar
I use it for pump lub & in place of anti-freeze . works good ......
V4f
V4F is offline   Reply With Quote
Old 04-05-2014, 06:16 PM   #9
jerry shook
I use it in all my 18 cars and trucks, works great, not expensive when it helps prevent rust and runs 20 degree.
jerry shook is offline   Reply With Quote
Old 04-05-2014, 06:17 PM   #10
jerry shook
20 degree cooler.
Old 04-05-2014, 07:27 PM   #11
roccaas
roccaas's Avatar
Works great in Southern heat.
20 years ago we had Johnny Cash, Steve Jobs, and Bob Hope. Now we have no Cash, no Jobs, and no Hope...please don't let Kevin Bacon die!
roccaas is offline   Reply With Quote
Old 04-05-2014, 10:22 PM   #12
Marco Tahtaras
Marco Tahtaras's Avatar
Water Wetter is the ONLY thing I've used with distilled water that has proven to be corrosive to brass radiators. Since about 1976 I've never used antifreeze in a Model A since it seems to create passages to seep through and around original type gaskets where water won't. Also, I'm near the West coast where lengthy severe LOW temperatures don't exist. Water Wetter was the ONLY additive I've ever used that not only did not prevent corrosion but proved to be corrosive to my brass radiators. Unfortunately I ran it concurrently in two cars with beautiful original radiators (admittedly thin from previous decades) and it took out both cores almost simultaneously. They had both cooled the cars perfectly under all conditions for 10-15 years.
In all fairness it would likely take years for it to show damage to a NEW brass radiator core which most folks run. Personally I'll never get near the stuff again.
A couple years ago when I was faced with the strange phenomena of loosing not one but two radiators under seemingly optimal conditions, the common denominator hit home and I spent about eight hours straight doing research. I found several well documented instances of similar results.
http://www.abarnyard.com/
Marco Tahtaras is offline   Reply With Quote
Old 04-06-2014, 06:51 AM   #13
James Rogers
James Rogers's Avatar
I agree with Marco, water wetter is just a band-aid and is corrosive. I only use water with Gunk waterpump lubricant and anti rust. Antifreeze is not only slick and will find a way to get under a gasket but, it is very abrasive and will take out the mains and rod bearings in short order if it seeps into the oil and is run for long without knowing the seep exists.
The Gunk lube is cheap at 1.50$ per treatment. Only need to add it when the water is drained.
James Rogers is offline   Reply With Quote
Old 04-06-2014, 02:29 PM   #14
christian
christian's Avatar
I've been using a 50/50 since I got my SW on the road, thinking about going to distilled water, but im concerned about the rust issue. This Gunk additive you mentioned, it functions as a rust inhibitor?
1931 Slant Windshield fordor
christian is offline   Reply With Quote
Old 04-06-2014, 03:16 PM   #15
James Rogers
It is basically water soluable oil. Mixes with water and lubricates the pump and oils the internals of the engine.
Old 04-06-2014, 02:35 PM   #16
Tom Wesenberg
Tom Wesenberg's Avatar
I wouldn't use soap for fear of corrosion. I used liquid dish soap to mount tires on my VW Rabbit aluminum rims until I found it was corroding the aluminum and I had a lot of rim leaks. I then started using Vaseline to mount and demount tires on both aluminum and steel rims. No corrosion and they hold air better than any other method.
As far as my cooling systems, I'll stick with 50% antifreeze and water. I've never had a problem because of antifreeze/water mix.
Old 04-06-2014, 05:21 PM   #17
Smog Tech
Smog Tech's Avatar
I agree with Tom. 50% antifreeze and water has always worked well for me. It is the only coolant recommended by most manufactures.
Smog Tech is offline   Reply With Quote
Old 04-06-2014, 06:23 PM   #18
Mitch//pa
yep X3
Old 04-07-2014, 08:13 AM   #19
rocket1
If you are thinking about water wetter because your engine runs hot it's only a bandaid fix,some of the aftermarket radiators don't flow well causing high coolant temps.I have been running 50/50 antifreeze and an original radiator since 1961.
rocket1 is offline   Reply With Quote
Old 04-07-2014, 08:41 AM   #20
SteveB31
SteveB31's Avatar
I use water wetter in my race car (not Model A) that runs under extreme conditions at 14000 RPM. It does work, and is designed for that application.
A Model A Ford NEVER needs it. I have owned and driven Model A Fords for 30 years and driven them in all conditions from coast to coast. If you ave a good radiator, good fan and the car is timed right , you will NEVER run hot- ever.
The radiator is the key. If you are wanting to use water wetter rather then get a good radiator.......then save your money and get a good radiator, and use anti freeze and water year round and all your cooling problems are behind you.
Model A Fords are low compression, low RPM engines that just need a good radiator. Plain and simple. With a good radiator, under ANY conditions, it should never run more then 195 degress,
Steve Becker
Berts Model A Center
And use antifreeze. I sold 100 heads and several engines this winter to folks that thought their garage was warmer then it really was this cold winter. $20 spent on anti freeze would have saved them a lot of time and money.
SteveB31 is offline   Reply With Quote
