Old 03-20-2014, 11:32 AM   #1
700rpm
700rpm's Avatar
Default No engine number
I have a block that has never had a number stamped on it. It is .060 over. There are four Ford script ex. valves in it, and non-adjustable tappets. Can you experts tell me anything more about its origins or possible previous uses? Marine/industrial, perhaps, or after-market? No diamond on the block.
Ray Horton, Portland, OR
Old 03-20-2014, 11:43 AM   #2
1930artdeco
1930artdeco's Avatar
Default Re: No engine number
Was the number ground off? Maybe in preparation for a re-stamping that just never happened?
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 03-20-2014, 12:04 PM   #3
700rpm
700rpm's Avatar
Mike
I considered that at first, but now I don't think so. The number area looks full height and still shows original casting roughness.
Old 03-20-2014, 12:04 PM   #4
Joe K
Joe K's Avatar
Some rebuilders would simply rework the block and then set it aside for a future customer. If the new customer didn't demand that he repeat the number stamping - then it might not have been done.
My original truck engine was a red painted engine, possibly a sears replacement. It was fully worn out when I got the truck which showed 140K on the odometer. A typical life for a Model A engine was reported by my engine rebuilder at about 70K miles so this might have been the end of the second engine?
This no-number red engine has the 'as cast' appearance on the block. I've considered that when I rebuild this engine for use in the truck I would re-stamp to match the frame.
Isn't that the desired condition?
Not necessary for NH state registration, however.
Joe K
Shudda kept the horse.
Old 03-20-2014, 12:18 PM   #5
Kurt in NJ
Kurt in NJ's Avatar
It could have been a replacement block
It could be a " diamond" block, look at the space between the lower left corner of the valve cover and the Sydenham timing gear cover for a diamond
Old 03-20-2014, 12:31 PM   #6
Mike V. Florida
Mike V. Florida's Avatar
That's what i first thought of when I read the post.
Old 03-20-2014, 01:04 PM   #7
700rpm
700rpm's Avatar
I checked for that when I first got it; no diamond.
Old 03-20-2014, 01:14 PM   #8
CarlG
CarlG's Avatar
My "diamond block" was obviously stamped by an amateur as the font isn't correct and the numbers don't line up properly. But it does look like it was stamped on the "as cast" surface of the pad.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 03-20-2014, 06:26 PM   #9
SLPreston53
SLPreston53's Avatar
There are folks who have shaved the number boss in a milling machine and then went over it with a scaling tool. It is very hard to detect that this is not an original block without numbers. Might be what you have...
SLPreston53 is offline   Reply With Quote
Old 03-20-2014, 11:40 PM   #10
Mike V. Florida
All engines that passed final inspection and run in on the electric motor and was slated for installation in the Model A/AA was stamped with a number.
No number 1) it was removed, 2) Industrial engine.
As Ford assembled a series of what were called Industrial Engines during 1929 and 1930 they would not have a diamond on the block.
Old 03-20-2014, 11:44 PM   #11
John LaVoy
John LaVoy's Avatar
I have an industrial block with no number. It wasn't shaved off it was never stamped. I think that block used for farm implements etc. were left with out a number since they were not being used to license a car.
John LaVoy is offline   Reply With Quote
