Old 06-21-2013, 06:10 AM   #1
Atlantic28
Atlantic28's Avatar
Default Spare Tire Bolt Removal
Got a side-mount spare on my 29 CCPU. One of the bolts that holds the spare has threads that are worn to the point that a lug nut will not hold securely.
The bolt has a square section where it passes through the plate. Can't tell if it is swedged or not, but tapping on it did not seem to move it. Should I smack it with a 3 lb hammer, use heat, or ??? How do these bolts get held in place?
Doug
Atlantic28 is offline   Reply With Quote
Old 06-21-2013, 10:11 AM   #2
CarlG
CarlG's Avatar
Default Re: Spare Tire Bolt Removal
Go ahead and smack it with your 3# hammer. It will come out. Replacement bolts are available at most suppliers. Snyder's info:
This special bolt has a square shoulder on it. It is used on the side mount spare tire plates, and on the rear mount spare tire carriers that have a square hole in them. U.S.A
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 06-21-2013, 04:09 PM   #3
Mike V. Florida
Mike V. Florida's Avatar
They are meant to be swedged in.
Old 06-27-2013, 06:21 AM   #4
Atlantic28
Atlantic28's Avatar
Got the bolt from Snyder's. Now, how to I get the old bolt out? Tried hitting with 3 # hammer, but no luck. Heated the plate to expand the square hole, but no success. Now, I'm trying to drill the old bolt out. At this rate, I may just have to break down and buy a complete plate with bolts already installed.
Anything else I should try before giving up?
Doug
Old 06-27-2013, 06:38 AM   #5
jw hash
jw hash's Avatar
remove the plate and lay the head of the bolt over a socket and drive it out. use a socket that just fits over the head of the bolt
jw hash is offline   Reply With Quote
Old 06-27-2013, 08:34 AM   #6
ctvpa
ctvpa's Avatar
First did you try to use a tap and die set it freshen up the thread first?
Next you put an oversized socket on the nut, and the heaviest C clamp and with heat that can usually work. If not, use a press, just banging it is not the best, and you will need a press to get the new one in.
ctvpa is offline   Reply With Quote
Old 06-27-2013, 09:08 AM   #7
whirnot
whirnot's Avatar
Originally Posted by jw hash View Post
remove the plate and lay the head of the bolt over a socket and drive it out. Use a socket that just fits over the head of the bolt
x2
Bill Worden
1929 Roadster
1929 Briggs Town Sedan
1930 Closed Cab pickup
1931 Coupe
2 Smith Motor Compressors
1951 Ford F1
High Desert Model A's
whirnot is offline   Reply With Quote
Old 06-27-2013, 09:15 AM   #8
Atlantic28
Atlantic28's Avatar
The bolt in question had been subjected to many miles of vibration with no lug nut on it. Not enough metal left to rethread it properly.
JW had the right idea, at least for my case. Putting a socket over the head of the bolt and giving a healthy smack or two popped it right out.
The new bolt fits fairly loosely, so a press isn't needed. I used a cold chisel to swedge the new bolt in place. Seems to be holding nicely.
Thanks for all the suggestions!
Doug
