Old 06-07-2013, 01:00 PM   #1
1930artdeco
1930artdeco's Avatar
Default testing jets
I would like to test some jets and then adjust if need be. Would someone be willing to post pics of their flow tester? This way I can figure out how to build one. Also what is the best way to solder/seal and redrill the jets? I would like to find a way to fill the whole jet and then redrill if possible. If not I will just have to fill in the bottom and redrill it.
Thanks,
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 06-07-2013, 01:10 PM   #2
160B
160B's Avatar
Default Re: testing jets
Here is the one I built. 36" from centerline of overflow to centerline of test port. Valve is to throttle the pump flow. Do not use an elbow at the top for overflow unless you drill it at the top to vent the column. This is necessary as the syphon action of the overflow can reduce the column pressure.
1931 160B & 1931 68B
If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time?
160B is offline   Reply With Quote
Old 06-07-2013, 01:34 PM   #3
Bob Johnson
Bob Johnson's Avatar
Here is one I built. It is easy to build and does not need a pump, valves ... Since the water reservoir at the top is large the water level does not drop enough during a test to make any measurable difference in the results. Plus you can set the water level to whatever height you want.
Bob
Bob Johnson is offline   Reply With Quote
Old 06-07-2013, 05:42 PM   #4
Tom Endy
Tom Endy's Avatar
Go on line to www.ocmafc.com (the web site of the Orange County Model A Ford Club of Southern California). On the menu at left scroll down to "tech articles" and click. It will bring up a new menu. Click on my name at the top (Tom Endy) and it will bring up a series of articles. They are all adobe files and you are welcome to download and use any of them.
Scroll to the one on Zenith restoration. There are a number of photos of a flow tester along with the specs for the jets.
Tom Endy
Old 06-07-2013, 09:59 PM   #5
redmodelt
redmodelt's Avatar
You do not have to fill the whole jet, just the tip where the hole is. you will never drill a straight line if you fill the whole jet anyway and it would take too much effort for the fuel to be sucked through that long tiny hole.
Old 06-07-2013, 10:32 PM   #6
Bluebell
Yes, the rate of flow through a jet is dictated by two things;
1. the diameter of hole, and
2. the length of the hole.
Bluebell is offline   Reply With Quote
Old 06-08-2013, 09:37 AM   #7
redmodelt
redmodelt's Avatar
RE: 2. the length of the hole.
Please expand on that in relationship to the jets in a Model A carburetor.
Old 06-08-2013, 03:33 PM   #8
160B
160B's Avatar
Original jets are a certain length, but the inside diameter is not the same over the entire length.
At the tip of the jet there is an orifice, smaller diameter sized to deliver the correct amount of fluid. This orifice is say 1/32” long at say a # 63 drill size.
Now when you solder the tip closed you cannot control the amount of solder that flows into the tip of the jet. So let’s say after soldering you now have to drill a # 63 size hole through let’s say 3/32” length of solder. This jet now has the same size orifice of # 63 drill but since the orifice is now 3/32" long the flow will be reduced.
Also the entrance into the orifice is not the same gentle curve due to the results of soldering, so this will also reduce the flow because you have changed the entrance characteristics of the orifice.
I will upload photos when I resolve a missing security token that does not allow me to upload photos
Old 06-08-2013, 03:49 PM   #9
Mike V. Florida
Mike V. Florida's Avatar
Ryan wrote this a few years ago;
Are you getting a "Security Token Error?"
If so, please excuse it... It's a bug. Typically you get that error when uploading images. It just means that the images you are uploading are too large in file size.
Old 06-08-2013, 04:19 PM   #10
160B
160B's Avatar
Thanks for the input Mike V. Florida
Original jets
Soldered jets
Last edited by 160B; 06-08-2013 at 04:35 PM. Reason: aded Thanks for the input Mike V. Florida
Old 06-08-2013, 04:34 PM   #11
Pinstripe
Excellent information Thanks
Pinstripe is offline   Reply With Quote
Old 06-08-2013, 06:00 PM   #12
Sparky
Sparky's Avatar
Here's my tester. It's hard to se on the picture but there is a submersible pump in the water reservoir. There is a smaller supply tank inside the large one that supplies the water to the jets. The pump keeps the level of the water in the supply reservoir constant; the excess water overflows into the catch tank and gets recirculated.
Sparky is offline   Reply With Quote
