05-27-2024, 05:57 PM | #21 |
Re: A perplexing oiling problem - A new one to me!
The new shaft looks great, what a relief. (pun intended)
05-28-2024, 11:52 PM | #22 |
The gear on the solid shaft is absolutely worn out.
I would also look at the bushings in the pump housing. May be its time for a new pump? My opinion, Chris W. |
05-29-2024, 07:26 AM | #23 |
New bushings, driven gear and relieved shaft should do wonders for this pump. Sad as it was before, it did still pump oil, just not as much as I would have liked. So, with these new parts, I should be even more happy!
M. |
05-29-2024, 08:05 AM | #24 |
Hi Marshall!
These slides are a bit late in posting, but I thought I would post for others to learn what you are going through. Also, I added a slide about the hole in the front wall of the valve chamber which could have been the cause of a low oil level in the valve chamber.
Bob Bidonde |
05-29-2024, 09:47 AM | #25 |
Theoretically that model B. oil pump shaft should be worth a slight horsepower increase in a model A. due to the less pumping restrictions!!!
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask |
05-29-2024, 09:51 AM | #26 | |
I think it's generally a bad idea to put plastic things near powerful heat sources so I would rather pick the spot where Werner put the hose. |
05-29-2024, 01:26 PM | #27 |
O.k.
M. |
06-05-2024, 04:01 PM | #28 |
Guten Tag Marshall,
did you fixed the problem?
Beste Gruesse aus Deutschland, Werner Ford Model A, Roadster, 1928 Citroen 11 CV, 1947 Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version |
06-05-2024, 05:43 PM | #29 |
I just got things back together today after being sick with a bad cold for the past week. I tested the reassembled pump with a drill to prime it and check the flow. It seems o.k. and stronger than before. I started the engine a little while ago and everything seems fine so far. No suspicious noise from lack of oil. There's a problem with mismatched manifolds that is causing an intake leak, so I can't be sure how complete my repair is. I blew out all the passageways in the valve chamber and they were clear. So, with a positive priming and flow, I'm relying upon the oil pump repair being successful. 'Gotta be better than it was before!
Marshall |
