The Ford Barn
-   -   Oil pump removal ? (https://www.fordbarn.com/forum/showthread.php?t=85735)
39 STD 10-10-2012 07:07 PM
Oil pump removal ?
Started to strip my 59a block down for a rebuild. Got to the oil pump. Removed the screen & pickup, the lock wire & pump bolt into the block. I assume it should drop out of the block.This thing won't move. Am I missing something or is there a trick to get it out. It'll be replaced but I don't want to break the pump housing off in the block.
JM 35 Sedan 10-10-2012 07:28 PM
Re: Oil pump removal ?
Here is a recent post on the same question.
https://www.fordbarn.com/forum/showthread.php?t=85654
39 STD 10-10-2012 09:30 PM
Thanks. I did a search but nothing came up at the time.
Binx 10-10-2012 09:42 PM
Here ya go:
http://fordbarn.com/forum/showthread.php?t=85654
Mike in AZ 10-10-2012 10:19 PM
click on the links....they've already done the search....Mike
