The Ford Barn
-   -   Inserts & full oil pressure (https://www.fordbarn.com/forum/showthread.php?t=194106)
Kahuna 04-14-2016 06:30 PM
Can some of you very knowlegable folks give me an idea of the machine costs to drill a crank for full oil pressure to the rods? This would be using a counter-balanced crank
Then an idea of costs of machine work to do a full insert engine? Meaning the rods and the line boring, etc necessary? Also the costs of the insert bearings
Thanks so much
Jim
tbirdtbird 04-14-2016 07:25 PM
Re: Inserts & full oil pressure
you are aware of course that full pressure is not required to run inserts.
Keeping a rear main seal from leaking is quite a challenge if full pressure
Kahuna 04-14-2016 07:28 PM
Yes, I'm aware.
Thanks
Still looking for the info tho
Synchro909 04-14-2016 08:45 PM
You say you will be using a counterweighted crank. A new one or weights added to an original? If it is the latter, I'd advise against drilling it. It'll break.:eek:
mrtexas 04-14-2016 09:01 PM
Thanks so much
Jim
Inserts about the same as new babbit bearings. Try to find someone to do a good job on babbit. They are all dieing off.
Mike V. Florida 04-14-2016 11:27 PM
Thanks so much
Jim
So much depends on where in the country the shop is located. I assume you have called a local shop?
Here is some info so you can understand some of what is necessary;
https://www.fordbarn.com/forum/showthread.php?t=156839
There are some prices here;
https://www.fordbarn.com/forum/showthread.php?t=133529
George Miller 04-15-2016 06:20 AM
Plus 1
AL in NY 04-15-2016 06:11 PM
A drilled and counterbalanced crank will run you around $900.00. The align boring for insert bearings is another $500-600 and the insert rods from AER is another $550.00. You still have to modify the plumbing in the block for pressure. And since you have gone this far, you should probably add a high compression head and a good Stipe "B" cam, modified oil pump and new pistons, valves and springs. You are not talking about a cheap rebuild!!!!!!!!!!!!!
40 Deluxe 04-15-2016 07:48 PM
Somewhere a few years back I ran across plans from the 1930's for converting an A engine for aircraft use. This included drawings for drilling the crankshaft for full pressure oiling to the rods. So back then a drilled crankshaft was considered safe enough to pull you through the sky!
However, the plans included a special bell housing with tapered bearings to handle the prop thrust and radial loads with a short shaft connecting to the crankshaft. So that heavy flywheel was left behind, safely on the ground!
wensum 04-15-2016 07:54 PM
One of the correspondents to this forum who runs a Model A at Bonneville has said that the dipper big ends are good for fairly high revs.
If your car is substantially standard, why risk the crankshaft by drilling it?
Our car has pressure fed mains as per Charlie Yapps article in "Secrets of Speed" But dipper big ends.
With shell bearings I'm anticipating that it will be reliable despite being fairly well worked over
Keith
1929 04-15-2016 07:57 PM
My inserts were $700 extra, didnt get the full pressure because it was an additional $2,000.
PC/SR 04-15-2016 10:25 PM
Wensum: Does Charlie Yapp or anyone else give a maximum rpm number for dipper rods? "Conventional wisdom" is 4000 rpm, plus a few, supposedly based on a 50's SAE article but I have been unable to find it or any other documentation. Any objective information would be invaluable to all A drivers. What is your rpm limit? Not arguing, just asking.
wensum 04-15-2016 11:31 PM
I don't know the safe limit, but with the gearing on our car, it's rare that we need to exceed 3000rpm in every-day use
I'll try to track down the contribution by that member
Keith
JohnLaVoy 04-16-2016 09:18 AM
You can order the SCAT crank already drilled for pressure. That gives you a new counter balanced crank with the drilling done.
Kahuna 04-16-2016 10:37 AM
Thanks everyone for the info and advice
Jim
