The Ford Barn
-   -   What would cause my right front to be lower? (https://www.fordbarn.com/forum/showthread.php?t=317292)
ford38v8 08-22-2022 10:56 PM
Re: What would cause my right front to be lower?
Originally Posted by petehoovie (Post 2159569)
Looking at the picture, it appears as though you have a front-end wheel alignment problem as well...
Nah, it just looks that way because his spare tire is out of balance. 🤪
Tinker 08-22-2022 11:27 PM
Could be the picture. I run toe out. But not duck foot. doesn't really help his issue though. maybe something to look at.
Terry,OH 08-23-2022 07:40 AM
check for a cracked leaf in the front spring.
Look at the spring center bolt it has a square head that fits into a square hole in the front crossmember
Do look at the spring shackles to make sure the spring eye is under the front radius rod and one side has not flipped over.
sugarmaker 08-23-2022 08:05 AM
Nice truck! Leaning or not! Most 80 year olds lean a little too. Just saying. ...
Have fun with it!
Regards,
Chirs
randy993 08-23-2022 09:11 AM
I’ll get under it in the next day or so and see if I see anything that doesn’t look right. I had the steering box rebuilt a while back and had the alignment checked. Everything was good. Alignment and all suspension, per the front end guy, checked good. Thanks for the suggestions….
mike in tucson 08-23-2022 05:48 PM
I had an aunt who was er... rather large. Her husband weighed maybe 130 lbs. They bought a new 62 Impala. She always drove it. Last time I saw it, the car listed to port severely.....
Ken/Alabama 08-23-2022 06:28 PM
Could be the bottom spring leaf is broken on that side. That’s why the second leaf wraps the bottom leaf eye.
19Fordy 08-23-2022 09:46 PM
Could the shocks be causing it to have a tilt?
My bet is that it needs a new spring.
Robert/Texas 08-24-2022 07:41 AM
In my case earlier this year I was noticing that my '34 roadster was leaning some on the drivers side. I assumed that it was due to my weight and that the car was sometimes driven with no passenger. One day I decided to take a drive and noticed that it dropped much further. The main spring had broken about 3 inches from the spring eye. I bought and installed an NOS spring from the place in Minnesota and now it sits level.
