08-06-2010, 02:01 PM | #1 |
40 Panel Truck Update
Had my frame sand blasted and found some "swiss cheese" on the frame sides in an area about 8 inches on each side. I am of a mind to not do anything about it, but this is my first frame up build and I thought I would get some opinions. Thanks Pete
08-06-2010, 02:06 PM | #2 |
Re: 40 Panel Truck Update
Hi Pete, I think I'd try to patch or replace those sections as long as you've got the body off. Hope you're having fun with the project. Vic
08-06-2010, 03:41 PM | #3 |
Where do you live? Could TIG in a section for you.
08-06-2010, 03:49 PM | #4 |
Pete,
Since you've gone to all the trouble to remove the body from the frame, I'd recommend going ahead and cutting out the bad stuff and putting in some new metal. Looks like that area is at the front of the rear kickup which is a pretty common area for rust. Somebody on here makes frame repair pieces and if you didn't want to cut the frame apart, you could just use them to create face pieces to replace the bad stuff and leave the upper and lower parts of the rails in place. It's a pretty straight forward repair and isn't rocket science. Make the frame whole and solid and your project will last a lot longer. JMTCW. dw
I love this country; it's the damn idiots running the government I'm afraid of. |
08-06-2010, 04:25 PM | #5 |
Joe's antique auto in Uxbridge, Ma. is doing a 40 panel and would be more than happy to help.
08-06-2010, 05:18 PM | #6 |
08-06-2010, 06:22 PM | #7 |
It would be a piece of cake to just face that portion with some 1/8" plate, since the upper and lower rails are so well preserved. I would definitely repair that.
08-06-2010, 06:27 PM | #8 |
Precision Coachworks probably has the sections you need. Very high quality.
08-06-2010, 08:05 PM | #9 |
Thanks to all, I took a fresh look at it and see where I could cut out the bad parts and weld in new plate. The upper and lower lips are good.Covering with plate would not work as the body would not fit over. I might as well do it right.
I will post pictures when done. Pete |
08-06-2010, 09:44 PM | #10 |
You can do it. Determination and patience can usually overcome an unexpected "opportunity." It will look good the first, or second, or... too often in my case, third or more times! I look forward to your update. Al
36 Fords Rule! Visit at www.36fords.com. Last edited by Hamtown Al; 08-06-2010 at 09:44 PM. Reason: fat fingers! |
08-07-2010, 06:04 AM | #11 |
Pete,
Keep us posted |
08-07-2010, 07:56 AM | #12 |
I just used the Precision Coachworks pieces on my 40 frame. I recommend them highly.
