10-30-2012, 10:45 AM | #1 |
Differences between a 41 frame and a 40 frame
I keep thinking about Dennis Carpenters new 40 Ford coupe. Will a 41 Ford coupe frame work on a 40 coupe? I have a 41 Ford couple and somebody used it for patch panels and there is not much left of the body.
IF IT CAN NOT BE FIXED WITH BLASTING WIRE, JB WELD OR DUCT TAPE ---IT CAN NOT BE FIXED Do not get me started on the stupidity of ethanol. I think one of the monitors is from Iowa and he will delete the thread. |
10-30-2012, 11:08 AM | #2 |
Re: Differences between a 41 frame and a 40 frame
Go to Wescotts web site and get the 40 Body mount locations and check them against your 41 frame. I would be surprised if they were even close, but I've never checked.
10-30-2012, 11:28 AM | #3 |
No good - totally different. 41 car frames are more like the later model 42-48 cars.
Keep checking here and on the the HAMB - I've seen frames for sale close to you that were reasonably priced ..... matter of fact, I've seen running 40 Ford coupes for sale complete that were cheaper that Carpenter's body alone. |
10-30-2012, 08:11 PM | #4 | |
Most of the body is still on my 41.
IF IT CAN NOT BE FIXED WITH BLASTING WIRE, JB WELD OR DUCT TAPE ---IT CAN NOT BE FIXED Do not get me started on the stupidity of ethanol. I think one of the monitors is from Iowa and he will delete the thread. Last edited by sturgis 39; 10-30-2012 at 08:16 PM. Reason: 97 |
10-30-2012, 09:00 PM | #5 |
Speedway sells a 35-40 frame.??
10-30-2012, 09:57 PM | #6 |
10-31-2012, 11:24 AM | #7 |
41 Passenger frames are a one year wonder. Similar to the 42-48 from the firewall back.
Attached is a scan of a 46-48 diagram from an old body shop repair manual. |
10-31-2012, 01:13 PM | #8 | |
Karl Thanks for the reply. Those are sure nice drawings on your website. They get a lot of use by some of my friends. Thanks again
