09-02-2012, 08:26 AM | #1 |
zenith 33 VEM carb for 4 cyl Ford engine
City:
LES VANS
State:
FRANCE
Hello,
I search a UK Zenith 33 vem or VEM-2 updraft Carb to put on my model B(f) engine. Thank you |
09-02-2012, 02:44 PM | #2 |
Re: zenith 33 VEM carb for 4 cyl Ford engine
More info required. Are you after a B 4 1932-34 zenith carb, Derek in NZ.
09-02-2012, 03:17 PM | #3 |
Yes and no. I'm after a 1932-34 model b 4 cyl. zenith updraft carb, but for the little UK model B engine and not US model B. It's the same engine with smaller pistons and only 40 hp. It was produced to pay lower tax.
09-03-2012, 04:42 AM | #4 |
I have an English B4 engine here , complete . Think it has normal A carb on it , can check in the day light, Not 40 hp thats about the large one size . 1700 cc i think 30hp or around that, Put a normal one on it Derek
09-09-2012, 03:04 AM | #5 |
Thank you for your answer quickchange.
I think it's approx. a 2200cc engine. (same parts as model A or B : crankshaft, camshaft, rods, water pump, distributor, starter, exhaust manifold, ... ) I tried to start it with a model A carb but it doesn't run well. It's a little bit better with a larger Zenith carb and smaller jets. I join a picture of the original carb. |
09-09-2012, 02:27 PM | #6 |
09-15-2012, 03:05 AM | #7 |
Thank you quickchange.
I feel that with a model A or B carb, the engine is running too rich. ( 2 other test ) Somebody knows this carb ? |
10-14-2012, 04:35 AM | #8 |
I ran my engine with a new zenith VEM-2. Perfect !!! :-)
