Old 07-08-2012, 01:21 PM   #1
Harylufa
Harylufa's Avatar
Default Graphite rope seal "Questions"
Dear Friends!
I hope all of you be all right.
I have to assembly my V8 1946 and i have some doubts. I must install the graphite rope in the U-shape as it is showed in the picture.
My question is,
1)How long must the rope be in the upper and lower U-shape?
2)Must I make any threat such as put the rope in oil an entire day? avoid the dry rope against rotating metal?
Please I hope you can understand what I mean, I need your advice.
Thank you very much
Harylufa
I love my Ford V8 1946!
Harylufa!
Harylufa is offline   Reply With Quote
Old 07-08-2012, 01:28 PM   #2
jsemple6392
jsemple6392's Avatar
Default Re: Graphite rope seal "Questions"
Hary,
There should have been easy to follow instructions with your gasget set. It should contain an adjustable knife and a thickness guage that is "U" shaped which fits around the ends of your graphite seal. Once cut, it gives you the proper amount of rope sticking out past the flange. As for lubrication, the graphite already in the rope is the lube. Non-lubricated ropes can be soaked.
Good luck with your build.
Joe S.
Fat Fenders and Flatheads...doesn't get any better.
jsemple6392 is offline   Reply With Quote
Old 07-08-2012, 05:01 PM   #3
Harylufa
Harylufa's Avatar
Originally Posted by jsemple6392 View Post
Hary,
Joe S.
Dear Friends1
Look what I found in Youtube. It is exactly what I need to know.
What do you think?
https://www.youtube.com/watch?v=kSQWl...eature=related
Thank you very much.
Harylufa!
Old 07-08-2012, 06:09 PM   #4
Vergil
Vergil's Avatar
From gasket kit
GraphTite Rope Rear Main Seal Installation
(general Instructions - not applicatuion specific)
* This Graphtite rope seal is of proven, superior quality,
however, careful attention must be paid when trimming
to avoid fraying.
* Do not pre-soak in oil
* Press rope into place. Use a smooth rod, like a socket
extension, to press in and compact rope to approximate
the crankshaft seal journal diameter.
* Trim rope about .015" beyond flush using spacer. Cut
through rope and slightly into wood stick to ensure a
clean cut. (stick, spacer, and knife provided)
* Press protruding ends of rope down flush. Push any
loose strands toward the center of rope end. Apply
startup lube to rope surface.
* Coat all cap to block mating surfaces with sealant. DO
Not apply sealant on rope ends.
Vergil
Bigger fonts to aid in reading
Vergil is offline   Reply With Quote
Old 07-09-2012, 07:43 PM   #5
Harylufa
Harylufa's Avatar
Originally Posted by Vergil View Post
From gasket kit
to avoid fraying.
Vergil
Hi!
Ok, it is very interesting what you say, I think that I have not more questions.
Thank for your help!!!
Hary
Harylufa!
