06-26-2012, 01:13 PM | #1 |
Electronic ignition on a 47 flathead 6
Does anyone run an electronic ignition in their flathead 6? I have the 47 G series and as I was ordering parts, the guy suggested I may want to look into an electronic ignition.
06-26-2012, 01:58 PM | #2 |
Re: Electronic ignition on a 47 flathead 6
Check w/Bubba's Ignition Service here on the 'Barn - he will know if there is a conversion for your setup.
06-26-2012, 02:37 PM | #3 |
No problem on the conversion , however it has got to be 12 volts.
The six volt thresh-hold are too low to work well.... Does it use the two bolt crab unit on motor side ???? |
06-26-2012, 02:43 PM | #4 |
Bubba, if that is you posting, I actually spoke to you on the phone about the ignition in a 47 Ford Flathead straight 6 after I posted this. Didnt come across your # until afterwards.
06-26-2012, 02:45 PM | #5 |
And the distributor is on the front of the motor.
06-26-2012, 04:57 PM | #6 |
3 pedals, 3 gears, no valve-covers.. Now THAT is a hot rod !! https://www.youtube.com/watch?v=ZmwwB34vxJE |
06-27-2012, 06:25 AM | #7 |
There may be a problem with the distr cap.....those 46-47 G series motors used an unusual cap that is no longer available. Unless a different cap/rotor can be fitted, I wonder how this would be completed.
http://www.vanpeltsales.com/FH_web/F...A-12106cap.jpg
