Old 06-24-2012, 05:19 PM   #1
Aok
Aok's Avatar
Question Why the insert fabric roof and not steel
Just wondering why the Model A closed cars had the insert roof and not solid steel.
Aok is offline   Reply With Quote
Old 06-24-2012, 05:27 PM   #2
Jim Mason
Jim Mason's Avatar
Default Re: Why the insert fabric roof and not steel
I believe the tech needed to make the compound curves and welding weren't developed until few years after the A
www.jmodela.coffeecup.com
Fwiw, jm.
Jim Mason is offline   Reply With Quote
Old 06-24-2012, 05:44 PM   #3
ronn
I believe Henry was just trying to save a buck. He was good at that!
Old 06-24-2012, 05:47 PM   #4
peters180a/170b
peters180a/170b's Avatar
Henry was cheap !
peters180a/170b is offline   Reply With Quote
Old 06-24-2012, 05:51 PM   #5
Mitch//pa
it helped fuel mileage
Old 06-24-2012, 06:11 PM   #6
Gary WA
Gary WA's Avatar
Depression they need the steel!
www.whidbeymodelaclub.com
Old 06-24-2012, 06:27 PM   #7
Aok
Aok's Avatar
Thanks Jim I do remember reading that now that I see it again, the humor is also good
Old 06-24-2012, 07:38 PM   #8
Jim Parker Toronto
Jim Parker Toronto's Avatar
Also, with the rough roads, and the frames ability to twist, no flat piece of steel of that size and position, would remain straight and flat for very long!
Jim Parker Toronto is offline   Reply With Quote
Old 06-24-2012, 07:50 PM   #9
Marco Tahtaras
Marco Tahtaras's Avatar
Besides the steel stamping issues already noted, it was the standard in the industry for the time period. If you spent 17k on a new Springfield built Rolls Royce you would get the same thing except the roof covering was long grain GENUINE leather.
http://www.abarnyard.com/
Marco Tahtaras is offline   Reply With Quote
Old 06-24-2012, 09:57 PM   #10
FL&WVMIKE
FL&WVMIKE's Avatar
Ford was a few years behind in the full steel roof. Chevrolet and others had it before Ford.
MIKE
FL&WVMIKE is offline   Reply With Quote
Old 06-24-2012, 10:07 PM   #11
Marco Tahtaras
MIKE
And what year would that be?
Old 06-24-2012, 11:07 PM   #12
CHuDWah
CHuDWah's Avatar
Of the "Big-3" passenger cars, Chevrolet introduced the "Turret Top" in 1936. Although competitors claimed the all-steel roof would "drum" and damage passengers' hearing, Ford and Plymouth followed suit in 1937. There probably are other makes with steel tops that preceded Ford and possibly Chevrolet.
Interestingly, despite the steel roof, Chevrolet continued wood-framed bodies through 1936, years after competitors had pretty much abandoned them.
CHuDWah is offline   Reply With Quote
Old 06-24-2012, 11:53 PM   #13
Greg out west
Question Re: Why the insert fabric roof and not steel
Hi AOK,,,
Jim & Marco had it right. Wasn't Ford first with the "Steel top" late 31 pick-up ? Wasn't it built by Bud ?....
Greg out West,
Greg out west is offline   Reply With Quote
Old 06-25-2012, 03:12 AM   #14
Terry, NJ
Terry, NJ's Avatar
I always heard it was the fact that they hadn't figured out how to stamp a full steel top.
Yet, they didn't want to weld the the tops in and they were very good at body welding. consider the welds in the rear of the body. They could have simply extended this bead up and over the full body with out too much trouble. The hand work needed for the manufacture of the fabric top was time consuming and expensive. It wasn't the depression, it didn't happen for another two years (1929) with the worst or low point at July, 1932. So why didn't Henry give them steel tops? I dunno! Probably it was just another example of being stuck in time. They had always done it that way it worked pretty well. I believe the tops outlasted the engines in most cases, so maybe that was the deciding factor.
Terry
Terry, NJ is offline   Reply With Quote
Old 06-25-2012, 08:16 AM   #15
Deluxe Delivery
Deluxe Delivery's Avatar
I have heard that it was considered cooler. Air conditioning being a ways off yet, the common thinking was that a steel top would be like sitting in a tuna can and would bake the passengers. After testing, it was determined that it was indeed cooler with a cloth top but only by a minor amount. Also keep in mind that we were only a few decades removed from carriages and buggies. Engineers, stylists and workers were just doing what had always been done. No one questioned it because it was just the way it was done.
Deluxe Delivery is offline   Reply With Quote
Old 06-25-2012, 09:07 AM   #16
WTSHNN
WTSHNN's Avatar
The Budd steel-top pickup was introduced in late '31 (I believe August/September?). I have heard that it was the first production steel-top vehicle; just anecdotal information, never anything official. The Ford pickups in '32 and up were steel-tops as well.
-Tim
WTSHNN is offline   Reply With Quote
Old 06-25-2012, 10:56 AM   #17
31apickup
The Late 31 pick-up was the first Ford will an all steel roof. Alot of it had to do with the roads and the flexability of the bodies. If you went all steel something would have to give. Cars such as the Model A were originally design to move and twist.
31apickup is offline   Reply With Quote
Old 06-25-2012, 11:55 AM   #18
krswen
I read somewhere that until the mid-thirties U.S. steel rolling mills could not roll sheet wide enough to span the top. Can't lay my hands on the source now though ....
krswen
krswen is offline   Reply With Quote
Old 06-25-2012, 04:19 PM   #19
ford1
a friend of mine is building a 35 fordor chevy master delux, and it has a steel turret top, it fooled me i didnt think the steel tops were offered till 37, i seems nothing is certain
ford1 is offline   Reply With Quote
Old 06-25-2012, 04:31 PM   #20
Rainmaker Ron
Rainmaker Ron's Avatar
krswen
I am pretty sure you have it right! My company at one time maintained much of the equipment at a rolling mill and I was well acqainted with the engineering staff. The inability to roll wide sheets was the reason related to me at the time.
Rainmaker
Rainmaker Ron is offline   Reply With Quote
