Old 06-22-2012, 08:11 AM   #1
V4F
V4F's Avatar
Default Front fender braces ??
i have an early 1931 coupe . the front fender braces are round cast . is this the correct braces or should they be stamped steel ? which is a better brace ?? ... thank you .. steve
V4f
V4F is offline   Reply With Quote
Old 06-22-2012, 08:36 AM   #2
Aerocraft
Aerocraft's Avatar
Default Re: Front fender braces ??
It is my understanding that the stamped steel braces were introduced in the 1930 model year. Gar Williams
Aerocraft is offline   Reply With Quote
Old 06-22-2012, 09:23 AM   #3
Napa Skip
Napa Skip's Avatar
If I understand the Judging Standards correctly (Section 4, page 4-14 Revised 2011 ff) the front fender braces underwent a number of changes:
Thru April 1929 – forged with 3-bolt mounting;
April 1929 – stamped brackets with tapered channel and 3-bolt mounting (both forged and stamped used during April/May 1929);
November 1929 – stamped brackets with straight channel and 2-bolt mounting;
January 1930 – new forged design with 3-bolt mounting;
April 1930 – stamped steel with open side of the channel facing fender.
There were other changes having to do with reinforcements, channel length, etc., which are spelled out in the Judging Standards.
Skip Keyser
Napa Valley A's
Olympic Vintage Auto Club (1980-1982)
MARC of San Diego (1977-1978)
MAFCA (since 1978)
MARC (since 1977)
Model A owners belong in their Model A’s; Model A’s belong on the road.
Napa Skip is offline   Reply With Quote
Old 06-22-2012, 10:38 AM   #4
V4F
V4F's Avatar
wow ! thank you ! i figured they were older than my coupe ........
V4f
Old 06-22-2012, 01:11 PM   #5
Greg out west
Exclamation Re: Front fender braces ??
Hey Steve,
I'ed go with the forged type, much stronger than the pressed steel..The steel type tend to crack at the bottom.
Greg out west,
Greg out west is offline   Reply With Quote
