06-21-2012, 01:30 PM | #1 |
Small block ford valve covers??
I know for made a Mercury embossed valve cover for the 352, 390 FE engines so I started wondering if Ford also made a Mercury embossed valve cover for the 289-302 engine? If so does anyone have a set lying around that they may want to part with?
06-21-2012, 06:48 PM | #2 |
Location: Howell, Michigan, USA, The Peoples Slightly Overspent Demodependancy of Michigan
Re: Small block ford valve covers??
Ford never made them as far as I know.
06-21-2012, 10:43 PM | #3 |
Had a bone stock 68 Mercury Montego "J" code (302/4bbl) and the valve covers were "Powered by Ford".
Bill, certified Ford nut. 2016 F-150 2016 Focus 08 Shelby GT500 57 Ford Ranchero 36 Chevy, 351C/FMX, 8", Mustang II |
06-22-2012, 12:26 AM | #4 |
Thank you for the answers to my question
06-22-2012, 03:03 AM | #5 |
The other option is the valve cover adapters that let you put FE valve covers on a SBF.
06-22-2012, 07:00 AM | #6 |
06-22-2012, 02:33 PM | #7 |
I did what Sweatdreams discribed, only I did it on a nine inch housing. I had a Ford logo on about 1/8 steel from a shipping rack. A fork lift knocked it off the rack, and I didnt want anyone to trip over it. I cleaned it really well, and ground away all but the oval, then gently heated it to conform to the rear of the nine inch axle housing. I sweat brazed it on, and gently hand filed all the brass that showed. It held prime and paint with no problem. I had a Mopar fan convinced it was a rare Lincoln signature housing. Shame on me!
06-22-2012, 04:28 PM | #8 |
Don, you have to set the bar a little higher. Screwing with Mopar guys heads is well below your skill set................
06-23-2012, 08:53 AM | #9 |
LOL! Streetdreams, you are too kind.
06-26-2012, 08:20 PM | #10 |
1968 Cougars had a optional Cougar cat valve covers. Some repops are on epay. Not cheap but they look great and they look 100% like the ones I had back in the 60's.
10-01-2012, 09:04 AM | #11 |
I have a winter project planned to take the aluminum 302 Mustang valve covers off my 54 Merc. & take my router & remove the Mustang raised letters. Then find a Mercury with some letters I can put on my covers.
