Old 05-12-2012, 01:34 PM   #1
ericr
ericr's Avatar
Default Model "A" voltage regulator
a company on the Internet, and at least one parts dealer, advertises a cut-out that looks like an original but functions as a tue voltage regulator. Does anyone know anything about these?
ericr is offline   Reply With Quote
Old 05-12-2012, 02:39 PM   #2
SDJason
SDJason's Avatar
Default Re: Model "A" voltage regulator
I'm a relative newbie (bought my Town Sedan just over six months ago), but one of the changes I did was to get one of these, after noticing that my battery was being overcharged during regular driving (generator is set to 10 amps; the overcharging symptom was acid leaking out all over the place). For awhile my workaround was to drive with the headlights on for the first half of any trip I was on (resulting in a 10 amp discharge), then turn the headlights off when I judged I was around halfway through the trip.
No more overcharging, and the stock look remains - couldn't be happier with it. Just have to remember to notify anyone working on the car that you have it installed, in case they feel like polarizing your generator.
SDJason is offline   Reply With Quote
Old 05-12-2012, 02:54 PM   #3
Mike V. Florida
Mike V. Florida's Avatar
There are actually three types for sale.
Fun Products makes the regulator that looks like the cut out.
Tom Wesenberg makes one that mounts on the internal end cap
James Peterson has one that replaces the generator band
Old 05-12-2012, 03:32 PM   #4
Purdy Swoft
Purdy Swoft's Avatar
Actually its Fun projects!!! Not fun products, an easy mistake but fun products is a different company that sells a completely different product.
I use the Fun Projects can style regulator and love it. It installs just like the cutout but gives voltage regulation similar to modern cars. They have them in 6,8 and 12 volt versions.
Old 05-12-2012, 08:20 PM   #5
marc hildebrant
marc hildebrant's Avatar
Group,
What voltage does the regulator for a 6 volt battery use ?
Marc
marc hildebrant is offline   Reply With Quote
Old 05-12-2012, 08:38 PM   #6
Purdy Swoft
Originally Posted by marc hildebrant View Post
Group,
Marc
The 6 volt regulator would be used with a six volt battery. The 6 volt regulator is for a 15 amp maximum charge. You need to remove the generator band and adjust the third brush for a 15 amp max . Then you can remove the cutout and install the regulator in its place. Its just as simple to install as the cutout.
Old 05-13-2012, 07:52 AM   #7
lindy williams
I have used two of those regulators that fit inside the cutout can for several years without any trouble.
lindy williams is offline   Reply With Quote
Old 05-13-2012, 08:41 PM   #8
marc hildebrant
Let me try again.
To charge a 6 volt battery, what voltage is the "6 volt" regulator set to ?
Marc
Old 05-13-2012, 08:51 PM   #9
Tom Wesenberg
Tom Wesenberg's Avatar
Let me try again.
Marc
Mine will put out about 7.9 volts when not connected to a battery. When the EVR is connected to a battery, the battery will load the charging circuit and lower the voltage to a few tenths over normal battery voltage.
Old 05-13-2012, 09:45 PM   #10
jmeckel
jmeckel's Avatar
Let me try again.
Marc
The is not a simple answer to your question
Fully charged the voltage will be at about 2.25 volts per cell, a six volt battery has 3 cells so the voltage will be about 6.75 volts. To charge a battery the voltage will need to be over about 7 volts. Please note voltage is not what " charges " a battery current is what does the " charge ". Here is a url that may help you understand battery charging. http://batteryuniversity.com/learn/
Jon
"If you choose to not decide, you still have made a choice!" RUSH
Don't tell me what you know..... Tell me what you have done.
jmeckel is offline   Reply With Quote
Old 05-13-2012, 10:03 PM   #11
eagle
eagle's Avatar
I have the "regulator in a cutout can" from Mac's and it works flawlessly. I set my 3rd brush current to 16 amps, using a digital ammeter. I can run headlights for a couple hour drive and never have had a low battery issue. My typical charge current with a fully charged battery tapers off to around an amp or so. (thats reading from my old analog gage in the car, not too accurate...) When I am running headlights on low beam (21/50 bulbs) I am about on zero, with lights on high beam, just under zero a bit. I should hook up my digital ammeter and check to see what the readings really are but I've never had a problem so haven't done it yet.
eagle is offline   Reply With Quote
Old 09-30-2021, 02:44 AM   #12
ADB
Sorry to contact you here, am trying to send a private message but I get this message
To be able to send PMs your post count must be 10 or greater.
am interested in the EVR for my model A 1928 with a 3 brush generator, please can you give more details, am based in Johannesburg, South Africa , my email is [email protected]. Thank you and regards Alex
ADB is offline   Reply With Quote
Old 09-30-2021, 02:46 AM   #13
ADB
Att Tom Wesenberg
am interested in the EVR for my model A 1928 with a 3 brush generator, please can you give more details, am based in Johannesburg, South Africa , my email is [email protected]. Thank you and regards Alex[/QUOTE]
Old 09-30-2021, 10:39 AM   #14
Badpuppy
Sorry to say, I'm afraid you're out of luck.
James Peterson started offering his EVR about the turn of the century and sold many. i haven't seen any recent information concerning him; since it has been over 20 years I'm afraid James may no longer be with us.
A few years later John Regan created the FunProjects regulator, a simple replacement of the cutout. Because the main component in it became obsolete, he stopped producing them a couple years ago.
At some point Tom Wesenberg entered the fray with his design, which is quite good. Unfortunately for Tom, he lost just about everything in a house fire a couple months ago, and is unlikely to be producing them again any time soon.
Badpuppy is offline   Reply With Quote
Old 09-30-2021, 10:47 AM   #15
alexiskai
alexiskai's Avatar
Tom has said that he really wants to start up his generator work again, but yeah, it might take 1-2 years for him to get his ducks in a row.
Old 09-30-2021, 12:07 PM   #16
Utopia Texas
Utopia Texas's Avatar
Try Nu-rex out…
https://www.nurex.com/generator-cut-...ositive-ground
Their system has a heat sink to cool the diode.
Utopia Texas is offline   Reply With Quote
Old 09-30-2021, 12:12 PM   #17
alexiskai
alexiskai's Avatar
Originally Posted by Utopia Texas View Post
Common misconception – diode cutouts are not voltage regulators. The diode replaces the original electromechanical cutout mechanism, it doesn't add any function that wasn't already there.
Old 09-30-2021, 12:35 PM   #18
Utopia Texas
Thanks for the explanation….
