Old 03-20-2012, 08:24 PM   #1
Colonel
Default Rear Main Oil Leak
The rear main leaks pretty bad from the weep hole in the bottom of the fly wheel case. It has become untolerable to drive far. Is there any way to fix this short of pulling the engine and spending a lot of $$ ? Otherwise engine runs fine. Thoughts?
Colonel is offline   Reply With Quote
Old 03-20-2012, 08:36 PM   #2
Colorado Greg
Colorado Greg's Avatar
Default Re: Rear Main Oil Leak
Leaks can come from various places and leak out the hole in the bell housing. Check to see exactly where the leak is coming from.
http://antiqueenginerebuilding.com/REARMAINLEAK.html
Mine had a bad leak and I was embarrassed to park anywhere someone would see how bad it was. Mine ended up being a problem with the previous install of the rear main as well as too much clearance in the bearing. I adjusted all the mains and rods, installed the real metal seal correctly and no more leaks
"Betsy doesn't leak oil - she just marks her spot"
Colorado Greg is offline   Reply With Quote
Old 03-20-2012, 10:43 PM   #3
ctlikon0712
ctlikon0712's Avatar
Also make sure that crankcase pressure isn't forcing the oil out the rear main drain back tube. You do this by making sure your oil fill tube's cap isn't pushed on to tight and can allow the case to breath properly. The pressure pushes the oil from the pan, up the tube, and out the rear main seal if not vented properly.
Wanted: Simmons Super Power Head
Craig Likon 1931 150B
ctlikon0712 is offline   Reply With Quote
Old 03-21-2012, 07:12 AM   #4
Sparky
Sparky's Avatar
My leak was caused by a blockage in the oil drain pasage in the main bearing block.
Sparky is offline   Reply With Quote
Old 03-21-2012, 08:37 AM   #5
V4F
V4F's Avatar
my leak was caused by my K&N filter . not enuff breathing . installed pcv valve .......
V4f
V4F is offline   Reply With Quote
Old 03-21-2012, 09:20 AM   #6
newshirt
newshirt's Avatar
My leak was caused by the oil return tube falling off.
Ray White
newshirt is offline   Reply With Quote
Old 03-21-2012, 09:35 AM   #7
TinCup
TinCup's Avatar
The article referenced by Greg is an excellent place to start. Until then several online vendors sell what we call a diaper to help control the leaking until you can sort it out. Spend some time and search through some of the older postings on rear main oil leaks and you will find a wealth of information.
Rear Main Diaper
TinCup is offline   Reply With Quote
Old 03-21-2012, 07:19 PM   #8
Gary Gregory
Gary Gregory's Avatar
My leak was the missing gasket between the flywheel housing and block..at the end of the cam.
Gary Gregory is offline   Reply With Quote
Old 03-21-2012, 08:32 PM   #9
Bill Steiner
Over filling the oil pan can cause a leak. use 4 1/2 gt. Bill
Bill Steiner is offline   Reply With Quote
Old 03-21-2012, 08:44 PM   #10
KGBnut
KGBnut's Avatar
The drain tube for my Rear Main was seated too deep and bottomed out, obscuring the opening. It really was an easy fix.
Style beats speed any day, and with a lot fewer tickets.
KGBnut is offline   Reply With Quote
