Old 06-29-2010, 11:59 PM   #1
30Tudor
30Tudor's Avatar
Default Modern Parts Cross Reference List
I had a couple of requests for the Modern Parts cross reference list from various people following a contribution to the post “Modern Points Cross Reference”. I have been putting this list together over the past couple of years and it is largely based on other people’s contribution to fordbarn and through some other digging around. I did not keep track of who may have posted some of these in the old fordbarn so I hope I don’t offend anybody. No guarantee as to the accuracy of the information.
Also, I would have to say that generally the best luck and pricing I have had getting this stuff is through the Model A parts vendors like Bratton’s, Bert’s and Synders.
So... from the “Many Contributors to Fordbarn” and other miscellaneous sources, and making no representations as to accuracy or completeness, here we go:
Electrical:
Motorcraft DC-1 Condenser
Motorcraft DP104 Point Set
Points CS30 Echlin (original style)
Points CS751 Echlin (new Ford style)
Condenser FA5 Echlin
Rotor FA3 Echlin
Condenser-Mallory Dist MA3 Echlin
Starter Brushes F502 Echlin
Spark Plug 561 Champion (Wl6Y)
Spark Plug 3X Champion (avail on special order)
Coil (6 volt) IC9 Echlin
Coil (12 volt) IC14 Echlin (w/built in resistor)
Generator Cutout CU1 Echlin
Alternator (12 volt) 71273SE OCA (one wire, internal regulator)
Battery (6 Vo1t) 7200 Exide
Battery (8 Volt) 8201 Exide
Battery (12 Volt) 843578 Exide
LED Lights
Tail light - http://www.unitedpacificind.com/storage/file10.pdf
Marker lamps - http://vehiclelight.com/clli.html
Light bulbs - http://www.superbrightleds.com
Bulbs
Taillight Bulb (6 volt) 63 GE
Stoplight Bulb (6 volt) 1129 GE
Taillight Bulb (12 volt) 89 GE
Stoplight Bulb (12 volt) 1073 GE
Engine:
Overhaul Gasket Set FS800C Victor
Head Gasket Set HS800C Victor
Intake/Exhaust Gasket MS9800 Victor
Head Gasket 800C Victor
Valve (Intake & Exhaust) 211-1558 NAPA Engine
Valve Spring 212-1001 NAPA Engine
Valve Seat Insert (Int) 218-8535 NAPA Engine
Valve Seat Insert (Exh) 218-7535 NAPA Engine
Piston (Std) 224-2625 NAPA Engine (also avail. .080 over)
Piston Pin Bushing 223-3316 NAPA Engine
Cylinder Repair Sleeve 226-8024 NAPA Engine
Piston Ring Set (std) 506 Perfect Circle
K&N Air Filters: To fit Air Maze filter kits suppplied by Model A part's vendors: Part E-9257, Round Air Filter, Height: 5.5 in (140 mm), Inside Diameter: 2 in (51 mm), Outside Diameter: 3.5 in (89 mm)
See:http://www.knfilters.com/search/universal.aspx
Drive Train:
Clutch Disk R604 Rayloc
Pressure Plate CA1524 Rayloc
Clutch Pilot Bearing 6203-2RSJ NAPA Bearing
Clutch Release Bearing N1087 NAPA Bearing
Clutch Alignment Tool 675-1626 Balkamp
Wheels:
Front Wheel Inner Bearing 15118 Timken
Front Wheel Inner Race 15250X Timken
Front Wheel Outer Bearing 9074 Timken
Front Wheel Outer Race 9196 Timken
Miscellaneous:
Gas Cap for 30-31 703-1020 Balkamp
Fan Belt 25-20426 NAPA Belts & Hoses (also try NAPA #5L430 or 5L440 which is 1" longer) Consider an industrial cog belt if you have a generator as it will fit around the smaller pully better - TR22425)
Fuel Filter Gasket 730-9510 Balkamp (for glass bowl 30-31)
Radiator Hose (1-3/4') 611 NAPA Belts & Hose
Radiator Hose- (2”) 613 NAPA Belts & Hose
Spare Tire Lock 770-2441 Balkamp
Bearings (Courtesy of www.jmodlea.com):
PINION BEARINGS [799000Series]
Cone (2 used) Ford Number B4211 – Bearing Number 28156 [799085]
Pinion Double Cup Ford Number B4616 – Bearing Number 28314D, 28314XD [799086]
DIFFERENTIAL BEARINGS
Cone Ford Number B4221 – Bearing Number 28156 [799085]
Cup Ford Number B4616 – Bearing Number 28317 [799087]
MISC. BEARINGS {Ford Number}
GENERATOR SHAFT BEARING(FRONT) {A10093} - 6203 2RS
30Tudor is offline   Reply With Quote
